Wiseco Pro Tru +4cc Dome Piston Set
Old 12-15-2012, 07:45 AM
keith102371's Avatar
Question Wiseco Pro Tru +4cc Dome Piston Set
Anybody have any feedback on these or have used them?
Wiseco Pro Tru +4cc Dome Piston Set for 3.622" Stroke...... Looking to bump up compression on my build without having to deck the heads more and worry about PTV, Info on the build, LS1 block, Torquer V2 112cam, comp trunion upgrade ls7 lifters, ls2 trays, , PRC .650 dual valve springs, ported and decked .025 241 heads, LS6 intake, 1 3/4 Pacestter headers, 3' y with 4"catback and Vig 3600 stall. Car will be DD with occasional trips to the Dragstrip, since I'm only a mile from Atlanta Dragway
Old 12-15-2012, 11:34 AM
2000PewterT/A's Avatar
I don't have any personal experience with these specific pistons but I have had a good amount of Wiseco products and I can say they are top notch when it comes to their quality. I have a set of their -3cc Dome pistons in my engine right now. IIRC my compression was like mid 11.5:1 or right around there with stock chamber 243 heads. It been a while so I may not be exact on the compression but its close. I would still check PTV clearance in any build I am putting aftermarket pistons it just to make sure, especially since you said you 241s are decked .025.
Old 12-15-2012, 03:35 PM
11.5 with -3cc pistons? or did you mean +3cc?
Old 12-15-2012, 04:12 PM
My mistake, I had a typo and didn't check it over cause I was on my way out of the house. My compression is around 11.2ish. My pistons are flat tops with -3cc valve reliefs. I am also running a 6.125 rod and the block has been decked.
Old 12-15-2012, 05:34 PM
what kind of power did ya make on ur setup? 11.5 to 1 is about where i wanna be.
Old 12-15-2012, 08:00 PM
Never had it dyno I since I did allot of the tuning myself with help from friends. I would say in the 425-435 range would be a safe estimate without overstating anything. I do plan to throw it on the dyno this spring just for fun to see what it makes.
Old 12-18-2012, 08:53 AM
ckpitt55's Avatar
was looking at these pistons also....OP did you end up finding anything else out about them? they come with a 0.943" wrist pin, which I believe is floating. do you have stock rods?
They seem to be ideal for bumping compression - with a 0.045" gasket and your heads you'd be around 11.5:1 and 0.036" for quench on 6.098" rods. You gotta be careful with the DCR though, not sure where that would fall for your motor - depends on your cam specs.
Old 12-20-2012, 12:01 PM
ckpitt55's Avatar
OP, just called wiseco. These pistons are designed to be used with the Gen IV LS1, a'la the 04 GTO that has revised connecting rods with a bushed small end to work with floating pins. These wouldn't work with Gen III LS1 motors that have press fit rods unless you get your rods machined.
Old 08-02-2013, 11:30 AM
Super Hulk Smash
JakeFusion's Avatar
Bringing this back.
I like these pistons. A more budget oriented piston but with a lot of Wiseco's good features... and a nice 4cc dome.
If you run the Scat or Compstar 6.100" rods designed for the stock .945" wristpin, you'd have a nice rebuild on your hands... Especially with the Scat rods with the 8740 rod material. You'd be around $560 for the pistons and $445 for the rods. So 1k for 2618 pistons and 4340 H-Beam rods. Sounds good to me. Add rings and new bearings, a light hone, balancing assembly, and machine shops costs and you could be in a shortblock that could handle 750HP for 2200 or so.
Old 08-02-2013, 12:40 PM
PREDATOR-Z's Avatar
Guys domed pistons is an old school habit. Not very reliable in LS because of the knock sensors atop the motor. In race only engines that is different but for street I would avoid such practice on a III Gen LS motor.
Old 08-02-2013, 01:17 PM
Super Hulk Smash
JakeFusion's Avatar
Why is that? What causes the knock sensor to go apeshit?
Old 08-02-2013, 01:40 PM
PREDATOR-Z's Avatar
From my experience yes, finally had to run race fuel. I tried various combinations and results were similar in most if not all cases, after awhile I said f88k it and took the domes out for some flattops. I just got tired of kr and since this was a street motor I just went back to base.
Old 01-30-2014, 02:14 PM
redtan's Avatar
Bringing this back up. I was also looking at these but for a Gen IV LS2 block with the relocated knock sensors (compared to Gen IIIs). Would they still be a problem for that setup?
Old 01-30-2014, 09:15 PM
DietCoke's Avatar
Domes arent a problem at all, that poster is high. Have 5cc domes on my car.
Old 01-31-2014, 02:51 AM
Stumped1215's Avatar
x2
No problem with domes.
Old 02-06-2014, 04:51 PM
reaper68's Avatar
So these pistons will work with the floating wrist pins then. . . hmmmm
Quick Reply: Wiseco Pro Tru +4cc Dome Piston Set
