Does this compression calculator seems accurate?
Old 12-16-2012, 09:57 PM
I8UR4RD's Avatar
Default Does this compression calculator seems accurate?
Is more needed to get the true answer?
This is what I have so far, and its the only one that has not given me a crazy answer like 7:5:1
I'd like to know the formula for finding the real answer rather than plugging it in, or make my own calculator. I have looked at the other threads, and did not come up with much other than dead links, and programs requiring excel which I do not have.
Old 12-16-2012, 10:44 PM
soundengineer's Avatar
I use a calculator built into some engine software....
assuming head gasket of 4.030 as well...
and assuming the #'s in the left column are correct for your setup
I get 9.59:1
Old 12-16-2012, 10:46 PM
also, 3 of the ones I just randomly chose using google, also returned answers in the 9.53~9.59 range
Old 12-17-2012, 09:31 AM
wildcamaro's Avatar
^^^i got the same thing when I calculated it by hand...
Old 12-18-2012, 12:38 AM
ckpitt55's Avatar
This calculator is making the assumption that at TDC, the piston is flush with the deck surface of the block. This may or may not be true for the particular setup you're running - you would also need rod length, head gasket bore, and piston compression height to get an accurate number.
static compression ratio = (cylinder volume at BDC) / (cylinder volume at TDC)
BDC volume = (swept volume)+(gasket volume)+(combustion chamber volume)+(piston dish)
TDC volume = (combustion chamber volume)+(gasket volume)+(piston dish)+(piston-to-deck volume)
Old 12-18-2012, 04:05 AM
bww3588's Avatar
Most online calculators are going to be just rough estimates. It can get really fuzzy when you factor in ring land volume and actual gasket bore and thickness. The formula above is the jist of it for static. Dynamic is another animal.
Old 12-18-2012, 09:23 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
The calculator he used asks you to add or subtract the piston being in or out of the hole in the same line as gasket thickness. If the piston is out .005", you take the .005" from the .051" thick gasket, if it's in the hole, you add it to the thickness of the gasket. They just saved one step/calculation.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-18-2012, 09:24 AM
Exactly, they are just tools to get a good estimate of compression. 9.52 vs 9.59:1....who cares?
__________________
Old 12-18-2012, 10:05 AM
ckpitt55's Avatar
ah gotcha. missed that, sorry.
Old 12-18-2012, 11:01 AM
No big deal! I was looking for it as well, and didn't find it until I slowed down and read all the descriptions.
__________________
Old 12-18-2012, 01:00 PM
wildcamaro's Avatar
Yea usually when I calculate compression I assume a couple different scenarios as far as piston being out of the hole or in the hole and usually it is a negligible effect, like other guy said 9.52 or 9.59 same difference..
Old 12-18-2012, 05:57 PM
bww3588's Avatar
Of all the variables to be assumed, you pick the most critical...yea, it won't change compression by much, but there is no reason at all that you should have to guess on that. You should know deck clearance exactly.
Old 12-25-2012, 09:00 AM
I8UR4RD's Avatar
thanks for the replies. yeah I kept being told my compression is 9:3:1 (and im betting it is)
rods are 6.125
i have ls9 gaskets
lq9 block with (ive been told is a 9.225 deck)
heads are 3/4 deck
any more info i dont really have other than cam profile. 232/240 .595 /608 115
for some reason I thought all of that would come together to get the true result......but I am really more interested in the math behind it. Wanted to get the formula for the real answer.
Example
RL+DH/GT= Compression
Old 12-25-2012, 10:28 AM
bww3588's Avatar
Using that equation, you have a 183.52:1 compression ratio...
Old 12-25-2012, 11:32 AM
I8UR4RD's Avatar
yeah but thats not the equation thats just an example. with 183:1 CR I may as well have a bomb.
Old 12-25-2012, 12:13 PM
bww3588's Avatar
The actual calculations are in post 5. A few minutes with a calculator and you should be able to ballpark it pretty good.
Quick Reply: Does this compression calculator seems accurate?
