High revving valve/rocker/lifter combo LS3
Old 12-24-2012, 03:25 AM
Tomis's Avatar
Default High revving valve/rocker/lifter combo LS3
Hello everybody. I had purchased a LS3 heads and started looking for some adjustable rocker arms and what? Surprise, surprise found the ones that I am can not afford, compcams for 1400$, they definitely nice piece of machining, but little bit over my budget.
The reason I am looking for adjustables, because I am planning to run a roller cam lightweight lifters with boosted 427 iron block topped with LS3 heads, spinn it to 7500 at least. The engine is only for drag race.
Could you share some combos or give me some tips, I am quite new with the LS engines.
Old 12-24-2012, 08:30 AM
studderin's Avatar
Getting a good shaftmount rocker setup (jessel, TD) is going to be the best, less costly part (in the long run) for having a hi rpm engine. Going cheap will cost more, after you have to re do with good parts the 2nd time.
Either keep it under 7,500 and run the stock style hydro lifter cam. (stock type intake limited this too) Or go solid get good parts, and spin it what the valvetrain controls, and what your limited from the power adder? If you want to spin it over 7K
Old 12-24-2012, 12:38 PM
Gray86hatch's Avatar
My ls3's get reved 7500 with stock rockers and hyd roller.
Not really a big deal with the right cam and other parts
Tim
Old 12-24-2012, 12:55 PM
NW-99SS's Avatar
I found my Jesel's on eBay for $1000.00 shipped. Not a bad deal for adjustable shaft mount RRs.
Old 12-24-2012, 01:02 PM
A.R. Shale Targa's Avatar
Perhaps T & D is a bit cheaper
Old 12-24-2012, 03:17 PM
Tomis's Avatar
Forgot to mention, that I am going to use Holley modular intake manifold, so the intake is not limited to 7500rpm, I guess.
What are the good lightweight solid roller lifters? was looking at these : http://www.briantooleyracing.com/mor...r-lifters.html
LS1 style solid lifters are more affordable, even adjustable one's, unfotunatly :-)
Old 12-27-2012, 07:52 PM
Tomis's Avatar
I guess I am going to stick to stock rockers with comp upgrade, just need to find a good lifter/spring/cam combo to work to 7500rpm.
Does anybody have ls3 stock rockers for cheap, I neeed bolts pedestals and rockers, since the heads that i bought are bare.
Old 12-27-2012, 08:58 PM
Super Hulk Smash
JakeFusion's Avatar
I'd do stock rockers, comp upgrade, hollow-stem valves (if true ls3 you have), and something like PAC 1521 springs and Morel 5206. I'd also go with some Manton 3/8" pushrods tapered down to 5/16" ends to fit the heads.
Then you could probably look at an endurance lobe profile. That's going to be most critical. One of the better ones I know of is EHI/EHX lobes from Comp Cams.
www.flowtechinduction.com
properly matched componets that will last
Tim
Old 12-28-2012, 03:27 PM
Tomis's Avatar
So far I have a 221/221, 112 from Stock48, Issky chrom molly pushrods, LS7 lifters and Brian Tooley spring and titanium retainer kit: 155 lbs @ 1.780", 380 lbs @ 1.180", 400 lbs @ 1.130, coild bind @ 1.070". How does that combo looks like?
Old 12-28-2012, 03:34 PM
That is not going to support 7500 rpm let alone 6000
Old 12-28-2012, 03:55 PM
Tomis's Avatar
What is the limiting factor in this combo?
Old 12-28-2012, 08:57 PM
the cam
Old 12-29-2012, 09:09 AM
Brian Tooley Racing's Avatar
I've had those springs with LS3 valves and stock rockers turn 7500, but like Tim mentioned, the cam has too little duration.
Old 12-29-2012, 09:16 AM
Tomis's Avatar
Forgot to mentioned, that it is a turbo motor.
Old 12-29-2012, 09:59 AM
still too small
Tim
Old 12-29-2012, 11:50 AM
Here's a video of a turbo combination I setup with heads/cam. It has the same springs you have, stock rockers, LS3 intake valves, turning it 7300 rpm through the traps. This isn't his best pass, he went 5.20's in the 1/8 mile. But with turbos, why do you want to turn it 7500 rpm? What intake are you running?
Old 12-29-2012, 11:53 AM
Tomis's Avatar
Intake is modular Holley hi-ram
Quick Reply: High revving valve/rocker/lifter combo LS3
