Best heads for a max effort stock bottom end nitrous car!
Just as the title says. I've been in contact with Martin from Tick and he will be helping me with camshaft selection. I know Martin is a fan of the AI HCR 241 heads because of the additional piston to valve clearance these heads provide. I will be shooting no less than a 250 shot but more than likely 300-400 so the camshaft will be a max effort nitrous grind. I do not care about dyno numbers as I am more concerned with chipping away at the SBE nitrous record. All you nitrous gurus what are your opinions?
AI HCR 241
TEA or AI 243 heads with additional exhaust porting for nitrous
Trickflow 215s with additional hand work by Brian Tooley
Hand Ported 243's by Brian Tooley
Flycutting is not out of the question however I'm concerned with the integrity of the stock pistons with as much nitrous as I'll be spraying. Also I'm not interesting in spinning the car past 6600-6800rpm.
Regards,
Jacob
AI HCR 241
Regards,
Jacob
I would say the Trick Flows touched up by tooley will give you the best gains. If you want to use AI the ls6 head will make a few more hp over the 241 head and flows more air. If you are going for a new record at the track and want max effort you may want to look at the TFS 225s over the 215s just my opinion.
I would say the TEA CNC with some touchups from Brian would be ideal setup of your options... The larger runner on the TEA 243 heads will really shine on a nitrous setup. Or you could step up to a larger TFS head. They will both make great power. My personal test car is running the TEA st2 with Brians touchups and has done very well on the worn out 110k mile bottom end. My cam isn't ideal for the setup now but still works okay. I've only sprayed a 175 through it so far but plan on hitting it a little harder next spring when the tracks open back up.
The one good thing about the TFS heads is you can still keep stock P to V with the 2.04"/1.57" valves that come in them. That said you're still at 64cc which is 10.7:1, but as we discussed, with the amount of nitrous you're going to be spraying, that 3 tenths of compression isn't going to be missed all that much.
