L33 rebuild
L33 rebuild
Plan was to run a stock l33 with prc 1.0 heads and tick stage 2 turbo cam ! But I think I want to run forged pistons and rods with my ls1 58 tooth crank does any one make forged boost pistons for a 5.3 or will I have to bore up to the 5.7 pistons? Any help would be great !
If you have the cash to bore to ls1 specs go for it, more cubes the better...that being said if you can use rods they are the better floating ones on an l33...if you go with stock size pistons you will have to get some 4.8 pistons, bc I also have an l33 and couldn't find pistons for it since all other 5.3s are dished, but the 4.8s are same bore, compression height, etc. good pick on the engine though!
