ls7 lifter???
The two are unrelated. LS7 lifters are nothing special, just the standard GM lifter. The trunnion upgrade addresses the issue with dumping bearings and tightens up clearances in the rollers. However, GM did fix the rocker design later so depending on the year of the rockers the trunnion upgrade may not even be necessary.
ls7 lifters here and NO trunion upgrade..been that way for bout seven years H/C/I..not gonna hurt you to upgrade though..at the time when i put the ls7 lifters in no one was doing the trunion upgrade
FWIW,
Be sure to check pushrod length after installing the lifters. The pushrod cup depth (where the pushrod sits) is a different height than a ls1 lifter.
Ls1 lifter - higher cup depth
ls7 lifter - lower cup depth
