Oil pressure....
Oil pressure....
My car is running a ported ls6 oil pump. I just put the head back on and new valve covers with a filler hole that i out a valve cover breather on. My problem is at WOT the oil pressure on the dash goes to 70psi. Is this normal or am i at risk of spinning a bearing?
Moderator
Pressure and volume are pretty much opposites. You only need enough pressure to supply enough volume, and pressure doesn't contribute to maintaining the hydrodynamic wedge keeping the bearing and journal from meeting. Excessive pressure is just making the pump work harder and causes parasitic loss.
If you don't have a big leak when the volume goes up so does the pressure.
My pump moves more GPM than the big melling. This pump has been proven to fix problems that guys were having in the Tx mile with burning up rods and mains. NHRA super stockers were also having issues.
I will take a little loss in power and have the engine live any day.
Tim
Tim
Moderator
Tim
Tim
As far as your pump, I don't know what you are using but the Katech LS7 pump in the engine I built kept it alive for the TX Mile, and WOT is maybe 50psi and 30ish at idle. Whatever tricks were done to your pump likely have more to do with resisting cavitation than increasing pressure.
Tim
Tim
what pump are you running tim?
there is a point where you can get too much pressure...but it takes a bit to get there. 80~100 is not too high...
if you were seeing 150psi... I would be worried.
typically the issues you will see from High pressure is usually blowing out the oil filter seal or blowing open the oil filter all together...
cant distort readings from it, but you can break the sensor and then it will have issues or leak oil from the sensor
yes, that's what I'm afraid of, too much pressure then you'd start blowing out gaskets and seals.
And it just so happened that when I did my heads swap I broke the opsu(my oil pressure was always around 40ish on idle) now with the new opsu, it always floating around 60
