Measuring to zero lash with 1.7 rocker arms. Questions...
I need longer pushrods on an engine that I'm building. I'm trying to obtain a measurement to zero lash. Since I am taking a measurement on the valve side with a feeler gauge instead of a PR length checker I would have to divide my measurement by my rocker arm ratio which is 1.7 to get me to my needed measurement of zero lash (or size to increase pr length by)....
Correct?
Correct?
Correct?
Correct?
Correct?
Correct?
I like to lift the rocker tip to get zero lash rather than try to rotate the pushrod end. Just gently lift it until the "tick" "tick" just disappears. (If you lift to hard on a dry lifter it will actually depress the plunger in the lifter.) Then you can cross check with the value you get with the feeler gauge.
These engines are not like small block Chevys that used zero-lash hydraulic lifters ,,,,,,,,,,these have .060-.080" of pre-load so You really need a push rod checker to measure with for what You need ,,,,,,,,,,,
I understand that but the pre-load is how much the piston in the lifter is depressed and unlike small block chevy 1st gen which have zero pre-load, LS based gen 3 / 4 have pre-load
You've got to be kidding Me ,,,,,,right ,,,,,,,,,You're going to let a word interpretation error or a lack of communication sway You're opinion about someone ,,,,,,,,,,Me ? ,,,,,,,Wow ,,,,,,,,,,I really have no reason to explain My credentials so good luck with the language
