Help! Metal parts in engine oil
Hi!
I have changed my LS1 98 trans am engine oil. Only 38000 miles. I found the metal parts of the pic in the oil drain plug...
The car runs smooth and perfect, also in high rpms. ONLY at idle you can appreciate slighty little noises like a free screw or something inside. No drops in rpm, but motor doesn´t have a uniform vibration. Can you help me?
Thanks!
Milimeters...
Thanks!
Milimeters...
Your engine is probably fine . How any miles and mods ? Time for trunion upgrade http://www.summitracing.com/search/p...trunnion-kitse .
Jurgen, is a completely stock LS1 with 38000 miles.
New rocker arms? Im in Spain. All parts are ordered to USA... I must be completely sure what part I need replace. This is the reason I posted the problem here.
Good luck .
http://www.summitracing.com/parts/CCA-13702-KIT/
