Cold engine start up Tick. LS1
Hey guys, ever since it has gotten cold I've noticed this more and more. When my engine is cold there is a noticeable tick coming from my engine bay. It will continue to tick until the temp gauge gets to the first mark and then it goes away. I changed my oil about 2 weeks ago, Mobil 1 10-30 with a new Mobil 1 oil filter. It definitely is RPM dependant and seems to be coming from my valvetrain. Is there some immediate danger here to really screwing up my engine? It doesn't last long but it bothers me. What measures should I take here?
Thanke guys.
Thanke guys.
If you can, try to isolate it to a pair of lifters. It should be fairly easy to tell the general location the noise is coming from. Then you can pull a valve cover, take rockers and push rods off the suspected lifters and shoot some B12 chemtool cleaner down the push rod holes with the intent of shooting it through the lifters. This should clean out anything that may be clogging it up.
A video description (no, it's not me):
