Attention all gearheads need advice
I WAS PUTTING MY TRANNY IN AND I WAS TURNING THE ENGINE OVER TO PUT STALL BOLTS IN AND BOOM THIS HAPPEN SOMEONE PLS TELL THERES ANOTHER WAY TO GET IT OUT WITHOUT TAKING MY MOTOR OUT
You might try searching this problem extensively before you go any further. I believe there are many threads in regards to your problem.
Metal shavings will not get into the engine oil or any other internal area as long as the oil pan and front cover are still on which I assume they still are....
This is a big problem but it can be fixed.
ok i got another question guys. my motor was sitting up for a while and got a good amount of water into it. and i think the bolt broke because the engine may have just rusted on inside and it was really hard to turn at one point
it turns far enough to get 2 converter screws in then it get really hard and thats when the bolt broke. my plugs are still in, matter of fact i have everything on except water pump, crank pulley, and radiator
If you're worried about rust and it holding what's left of the bolt, look for some Deep Creep Penetrant. That stuff works pretty good. Then hit it with the easy out like suggested above.
