Heads that flow well on the exhaust, or intake? Which is better?
There are so many heads on the market these days that advertise great flow #s on the intake side, but only average on teh exhaust. My question is... it you found a head that gives up a little flow on the intake side over brand x, but flows quite a bit better on the exhaust side, which one would you choose?
A cam can be custom spec'd/ground based on the intake and exhaust flow of a given set of heads. Take for instance AFR heads. The intake and exhaust both flow great, so in theory, a 4 degree or less split cam generally does very well and produces great numbers. If I were you, I wouldn't get so caught up on the flow numbers. Whatever head(s) you're looking at, search for some "real world" results like dyno numbers and track times. Take a look at the entire combination too and see how a given cam performs with the heads. If you're in the market for aftermarket castings, then take a look at AFR, TFS, PRC, PI, etc. Even ported stock casting LS2 heads do great. Some of the best porters out there are Advanced Indcution, Livernois, TEA, Flowtech Indcution, etc. It really depends on how much you want to spend and what your goals are.
Thank you very much for your response. I have looked at almost all of the companies you listed. This is where the confusion lies. My head is just spinning in circles. How do you choose? This is why I started this thread. Do I just go for the best "advertised" flowing head? What should I be looking for? Peak numbers? Mid and low lift flow numbers? How critical is exhaust flow? I'm looking for a powerful, streetable setup. A nasty cam sounds great, but driveability is very important since my car is a street car.
