Parts List for Heads/Cam Install?
I'm getting a parts list together for my H/C swap and would like some input on what's needed, what's not, and what's missing.
Definite -
Heads
Camshaft
Head Bolts
Head Gaskets
Header Gaskets
Lifters
Valve Springs/retainers/Locks/seals
Camshaft Bolts
Timing Set
ARP Crankbolt
Pushrods
Comp Trunion Upgrade
Oil Pump
Injectors
Spark Plugs
Engine Oil
Oil Filter
Engine Coolant
Thermostat
LS2 Water Pump (for future FAST 102)
O-Ring for Oil Pickup Tube
Paper Towels
Loctite
ARP Thread Sealer
ARP Assy Lube
Brake Cleaner
Are the items below needed?
Lifter Trays
Valve Cover Gaskets
Camshaft Retainer Plate/Seal
Cam Retainer Plate Bolts
Throttle Body Gasket
Cam Install Gasket Kit
Timing Cover Gasket
Valley Cover Gasket
Knock Sensor Grommet
Intake Manifold Gasket Set
Head Alignment Dowels
Head Steam Vent Gaskets
Front Crankshaft Seal
Harmonic Balancer Installer
Deep 27mm Socket
Cam Degree Wheel
THANKS!
Definite -
Heads
Camshaft
Head Bolts
Head Gaskets
Header Gaskets
Lifters
Camshaft Bolts
Timing Set
ARP Crankbolt
Pushrods
Oil Pump
Injectors
Spark Plugs
Engine Oil
Oil Filter
Engine Coolant
Thermostat
Paper Towels
Loctite
ARP Thread Sealer
ARP Assy Lube
Brake Cleaner
Lifter Trays
Valve Cover Gaskets
Timing Cover Gasket
Valley Cover Gasket
Deep 27mm Socket
Cam Degree Wheel
THANKS!
Some of your questions have many answers. it will help if you can give a little more info
What kinda block are you doing this to? Not all builds are equal or right for your intentions.
1st question what's your goal? What do you want track only, street, dd?
You can build a track monster but can't drive it to work.
Other questions are budget & ability.
How much you are willing to spend?
Can you do the work? have the tools & knowledge?
Answer these and you'll start getting some suggestions.
You will also need a puller for the balancer and a set of metric line wrenches. I would replace all gaskets on all of the mating surfaces of every part you remove. Gaskets are cheap and you don't want to spend all that time just to have to tear it back down because of a leak somewhere. You will also need a valve spring compression tool to compress the springs to remove old retainers. Replace the belts and hoses while you are in there. LS1howto.com has lots of useful information about bolt locations and torque specs for the tear down and reassemble. FWIW when reinstalling the balancer,clean the balancer and put it in the over at 300* for about 15 min. Get it nice and warm and it will help with getting it back on the crank without too much trouble. Do not use your new balancer bolt for the install you will risk stripping the threads on the crank and then you will be fucked like a tied goat. Good luck with the install.
Do I need new lifter trays?
What about Valve Cover Gaskets?
Camshaft Retainer Plate/Seal?
Cam Retainer Plate Bolts?
Throttle Body Gasket?
Valley Cover Gasket?
Knock Sensor Grommet?
Intake Manifold Gasket Set?
Head Alignment Dowels?
Head Steam Vent Gaskets?
Yep, I have all that stuff on the list. It was more the gaskets I'm questioning.
Valve cover gaskets?
It just doesn't seem like most people replace all these and I'd rather not replace parts I don't have to.
What timing set should I go with? An LS2 or a comp double roller?
http://www.texas-speed.com/p-651-gm-...chain-set.aspx
http://www.texas-speed.com/p-2280-co...-sprocket.aspx
