Stupid Question: Bolt Reuse?
Hey guys im building my first LS engine and was wondering if i can reuse most of my bolts? I have purchased a short block with head studs so i was wondering if i can reuse my intake bolts, front and rear cover bolts, bell housing bolts, water pump bolts, ect. If not can someone tell me where i can purchase a kit of these bolts. Thanks in advance.
Yep, the reason you can not reuse the crank bolt and head bolts are because they have to be torqued down so much that it "stretches" the threads.... in turn when they get put back in they tend to back out. FYI
Thanks for all ur input the new motor will be a forged 408. So what bolts other than head and crank bolt are one time use that are not found in a short block sinse i purchased a assembled short block. Also on head studs do i have to torque the studs in the block or put them in finger tight?
Yeah i still have a few small things to get still but i hear good stuff about ARP so i though id get there stuff. Any of u guys ran LSA heads? Will the stock exhaust manifolds fit em? I cant seem to find info on them.
