What do I need to buy?
Old 01-30-2013, 09:46 AM
LS1SSZ28's Avatar
Default What do I need to buy?
I have an 01 SS Camaro, will be buying headers this weekend.
But my next step is heads and cam. i wanted to for the last couple years do the LS6 heads and cam mainly because there are some gains but i daily drive my SS. But everything ive read and heard is to do something that gives you a little more power.
I have all tools required.
Taking that into account, what would be a shopping list of stuff i need to do the heads and cam swap. Nothing outrageous, more a less a budget build but not extreme just looking for good gains for a DD
Old 01-30-2013, 09:53 AM
Tainted's Avatar
ls6 heads
cam
gaskets
bolts
springs
pushrods
trunion upgrade
oil pump
Old 01-30-2013, 09:54 AM
LS1SSZ28's Avatar
So even if i do want to go with something a little more aggressive still get the ls6 heads?
Old 01-30-2013, 09:55 AM
Tainted's Avatar
they are a great budget head.
if you have the money step up to some real heads, AFR, Trick Flow etc
Old 01-30-2013, 09:58 AM
LS1SSZ28's Avatar
What about buying a used set from a member on here?
Old 01-30-2013, 10:01 AM
Tainted's Avatar
sure, its a great way to save some coin. only thing when buying used heads is you may need to change the springs and sometiems the valves but I dont think the valves will be of any concern to you.
Old 01-30-2013, 10:03 AM
LS1SSZ28's Avatar
would 400+ Hp be a realistic number to shoot for but still have realiability and Driveability?
Old 01-30-2013, 10:04 AM
Tainted's Avatar
easily, and you wouldnt even need heads to hit that number. but, for 300-400$ a set of ls6 heads would certainly make that goal easier to hit with better numbers, and would really help a cam shine.
Old 01-30-2013, 10:27 AM
LS1SSZ28's Avatar
any good brands or cams to look for if i want to shoot for around 400+ and still have drivability?
Old 01-30-2013, 10:32 AM
Tainted's Avatar
theres so so so many to chose from. I suggest you research them and go from there, or have someone spec you a cam.
Heres a few to look at though, EPS, TSP, Tick, Vengeance, Livernois etc
One thing, with stock rockers, keep the lift under .630
Old 01-30-2013, 10:34 AM
Tainted's Avatar
also, are you M6 or A4? If youre auto youre probably going to need a stall
Old 01-30-2013, 10:37 AM
LS1SSZ28's Avatar
I have a m6, i replaced the clutch and flywheel about 2,000 miles ago.
Old 01-31-2013, 03:00 PM
LS1SSZ28's Avatar
http://www.ebay.com/itm/GM-Z06-Camsh...963373&vxp=mtr
would this work?
Old 01-31-2013, 03:11 PM
justin hover's Avatar
Check out Martins Cams @Tick Performance. He has a new line of cams, (and older ones of course) and his personal service is unmatched. He spent more than enough time with me on the phone to spec out my cam. BUT..do it right...read the stickys so you have a basic understanding. Do not get the zo6 cam...as in 2 yrs from now you'll be kicking yourself because you didn't go bigger. Just search DD cams. It'll bring up alot of options that you can start to dig into for more options and more of an understanding.
Quick Reply: What do I need to buy?
