Supercharge LS6?
Old 02-06-2013, 11:05 PM
Cali_Irishman's Avatar
Default Supercharge LS6?
Would this setup be able to handle a Supercharger running between 8-10psi?
Ls6 motor from 04 z06 fresh rebuild
Chromoly hardened pushrods
Double roller timing chain
Melling high flow oil pump
Custom grind cam
.600 lift PAC Racing springs
Ls7 lifters
Port polish heads and throttle body
Old 02-06-2013, 11:13 PM
conan's Avatar
Yes, as long as the tune is on the safe side. You could add meth as well for some extra insurance if you want.
What type of supercharger are you looking at ?
Old 02-07-2013, 08:10 AM
mark21742's Avatar
Good meth setups are cheap, easy and really help out...you can get a full kit for around $500. This can give you more power AND make your engine run safer/longer.
Old 02-07-2013, 10:20 AM
J Glen's Avatar
If you are going to spend that kind of money on such a nice build then put some quality link bar lifters in it.
Old 02-07-2013, 08:25 PM
mypoorLS1's Avatar
It all depends on the cam. You say "custom grind" That could make it go either way. Cam specs?
Old 02-07-2013, 08:45 PM
zzcamaro00's Avatar
correct, definitely put a quality link bar style lifter in, you have my vote there
Old 02-09-2013, 08:50 AM
dirtbag's Avatar
+1 Nice link bars should be on the list of ALL builds IMHO.
Old 02-09-2013, 08:56 PM
garygnu's Avatar
whats the compression ?what cam would you be using ?you need to watch your dynamic compression.
Quick Reply: Supercharge LS6?
