cam bearing help/opinions
I just changed cam bearings in my 4.8, i used the durabond bearings i have a universal cam bearing tool that ive used before, ive installed a few sets of cam bearing's and never had any problems. I put them in the order the box said to do. I got them all in and tried to test fit my cam after covering it in assembly lube and it went fine till i got the number 1 and 5 bearing and it did not want to turn anymore. After i did finally get it in the all the way i could not turn the cam by hand so i stuck a wrench on the cam gear and it turns free like its supposed to once you get it spinning but if you stop you have to apply alotta force to get it spinning again, Could this be because the bearings are to tight on the cam and while its spining the lube is between the bearing and cam better?? the cam is not bent and the lobes are fine and i cant see anything wrong inside the cam bearings, What would you guys do?
