Finally pulling the trigger on parts!
Old 01-27-2017, 06:39 AM
  #1121
BrntWS6's Avatar
Procharger has the D1x coming, supposed to give ~8% more power.
Old 01-27-2017, 08:46 AM
  #1122
kinglt-1's Avatar
I would go procharger...you have been planning for it. The new X series chargers look like they are closing the gap some in power vs a turbo.
Old 03-10-2017, 10:15 PM
  #1123
Super Hulk Smash
JakeFusion's Avatar
I keep promising videos of my pile.
I'll make some this weekend and post...
Old 03-11-2017, 01:14 PM
  #1124
WS6 #3392's Avatar
Looking forward to seeing it and hearing it.
Old 03-11-2017, 05:50 PM
  #1125
Super Hulk Smash
JakeFusion's Avatar
Was working on my daily driver today, so didn't have much time to go out and make any videos with the Trans Am. But I did find a little time to clean and polish the wheels and exhaust tips. So this is more of a trial run with cheapo GoPro I picked up to see how it would do with videos....
Old 03-12-2017, 10:38 AM
  #1126
mac62989's Avatar
Sounds good man! Quick question, what kind of polish do you use? I can never seem to keep those big *** exhaust tips clean..
Old 03-12-2017, 12:41 PM
  #1127
Super Hulk Smash
JakeFusion's Avatar
Borla makes an exhaust polish. I use it and bronze wool.
Old 03-12-2017, 02:31 PM
  #1128
kinglt-1's Avatar
Mother's liquid chrome polish...Stuff is amazing. That and a towel is all you need to remove water spots, carbon build up , and road tar.
Old 03-12-2017, 04:53 PM
  #1129
Super Hulk Smash
JakeFusion's Avatar
I'll try that.
The Borla is thick and cakes on. You have to use a Powerball or the bronze wool to get it off. But it works.
I usually just work in a dab with the wool and keep working it, moving to a cleaner piece of the wool until it's done. Then I use a terry cloth or even just a shop rag and get any residue out. Then I spray with the water hose to check to see if it needs a touch up.
It takes about 5 mins to do it.
Old 03-12-2017, 05:00 PM
  #1130
mac62989's Avatar
My issue has never been getting them clean it just seems like once I polish them and go cruising, I get home and their dirty already. Pisses me off
Old 03-12-2017, 05:04 PM
  #1131
Super Hulk Smash
JakeFusion's Avatar
The Borla stuff puts a protective coating on it. Lasts about a month before I notice them getting dulled out again.
Old 04-25-2017, 08:07 PM
  #1132
Super Hulk Smash
JakeFusion's Avatar
Started collecting more stuff...
Old 04-26-2017, 05:20 AM
  #1133
Coonass350's Avatar
That looks like the Straub kit, yeah?
If so I just installed their kit in my C6Z. Good quality stuff it seems. I'll post the link to my thread so you can see what the comp kit was doing. Glad I made the switch
https://www.corvetteforum.com/forums/c6-z06-discussion/3961935-upcoming-project-swap-comp-for-straub.html
Old 04-26-2017, 07:25 AM
  #1134
MIGHTYMOUSE's Avatar
good looking radiator shroud!
Old 04-26-2017, 08:00 AM
  #1135
KCS
Moderator
KCS's Avatar
Looks a lot like the cold side of a HSP turbo kit....
Old 04-26-2017, 09:23 AM
  #1136
Super Hulk Smash
JakeFusion's Avatar
You would be correct.
And that shroud is ****. I'm about to throw it on just to free up a lot of space under the hood and wire in the SPAL fans before I even get to the go faster goodies.
And yep, Straub kit. I weighed it vs the CHE kit. Almost did CHE since I know that kit is insane and Kurt Urban helped with it. But the Straub kit is fine for what I'm doing, and the price was better.
Also swapped over to JGR Driven LS30 oil. I'll see how it does. I should be able to get 3k if not 5k miles out of an oil change with it vs the VR1 I was using. Plus, the LS30 has a higher shear rating and more ZDDP...
Old 04-26-2017, 09:28 AM
  #1137
Received 3,017 Likes on 2,348 Posts
Are there any physical differences between the Straub and CHE trunnion kits? Sorry for the hijack....
Old 04-26-2017, 09:47 AM
  #1138
Super Hulk Smash
JakeFusion's Avatar
CHE doesn't have to be pressed in. And it as perhaps a better oil groove system around it. At the end of the day, both are bronze bushings running on an oil film. So, how you get there is what makes them different. I believe the CHE bushings are lighter, but the weight is on the trunnion/lifter side and not the valve side, so for the RPMs most of us turn I don't think it'd make much of a difference.
Old 04-26-2017, 10:06 AM
  #1139
OK, thank you Jake! Always wondered about that, and you cleared it up!
Old 04-26-2017, 01:09 PM
  #1140
BrntWS6's Avatar
You planning to forge the motor? I have not heard of that oil, been using the VR1 for a few years now. Ill have to check it out.
Quick Reply: Finally pulling the trigger on parts!
