AI LS6 heads vs TEA STAGE 2 LS6 heads vs TFS 215s
Looking into getting a good set of heads for my c5z. I already have LG sport long tubes, borla catback, vararam, and a 226/234 EPS cam. Soon id like to add a set of heads, a Fast 92 and a bigger tb. Looking into the TEA stage 2 ls6 heads, but i saw a link of a red c5z with the same cam and mods ill have, with tfs 215s that made great numbers. A buddy of mine has a set of AI 243s with a biy bigger of a cam that also put down great numbers. Any opinions, on whats the best bang for your buck?
Super Hulk Smash
Can't go wrong with any of them.
I'd go with an LS6 head tho since you already have it. Both TEA and Ai can port your existing 243s and reuse your existing valves (highly recommended since they are lightweight). Price is a little cheaper with TEA if you do that since Ai charges 999 + springs (250 or 300) and TEA includes PAC Dual Springs for 1199. And you aren't really giving up much power if any to the TFS 215s and you'd keep good piston-to-valve clearance and can keep your stock rockers (best for the LSx) without having to upgrade the heads to make them work.
I weighed my options and came down to TEA and Ai. I ended up going with TEA, but that was a personal preference. I did their Stage 2 since I don't think it gives up any to the TFS 215s... Talk to them both and go with whomever you feel more comfortable spending money with.
I would purchase a 92 from them but i dont see it on their site. I dont want to use a 102 because my brother had to drill holes in the cowl of his car to put the last 2 bolts in.
More than likely ill go with the TEA stage 2 heads, and have them put lighter valves in them. Trying to keep this on somewhat of a budget, but from what ive gathered the difference in gains isnt much. If im using a stock casting head i shouldnt have to buy different rockers. And i will deffenately discuss using turned down ls3 valves in these heads.
Im really just trying to get the best bang for your buck ported GM head.
10 Second Fun Car
I have the 102 and didn't have any issues. Call and talk to them about what you want, not everything they have is on the website. The heads will work with stock rockers as long as you get the powdered metal guides installed on the 215s. This is my second set of heads from TEA. I had a Stg 1 5.7 head that made great numbers and was even put on a 408 that made 480hp and 480tq. They do great work and have excellent customer service.
Super Hulk Smash
I have the TEA Stage 2 heads. Mike talked me out of the LS3 valves because I have a fairly mild cam (EPS 230/234). So it doesn't need the lighter valves because I won't see enough RPM to stress them. Plus when using the stock rockers, you eliminate a lot of issues that normally plague the TFS 215s + heavy roller rockers. The springs just can't handle the valves, aggressive profiles, and heavy rockers like Harland Sharp with hydraulic lifters. Take any of those issues out of the equation and you have stability upto 6800 fairly easily. Take all of them out and you have 7500+ RPM capability.
