Most reliable rocker arm for trick flow heads
Old 02-15-2013, 03:58 PM
ihdude's Avatar
Default Most reliable rocker arm for trick flow heads
I currently have stock rocker arms with truion upgrade and I'm looking at some trick flow heads. What are the most reliable rocker arms or can I change out guide plates and use my stock ones. If so, what kind of guide plates should I replace them with to run the stock rocker arm?
Old 02-15-2013, 04:18 PM
Tainted's Avatar
Jesels
Old 02-15-2013, 04:52 PM
Quick Ranger's Avatar
From what I gather, if you have powdered metal guides installed, you can use the stockers. But, if I were to run aftermarkets, it would be jesels. It seems to many issues with other roller rockers. I've ran jesels on older BBC engines with great results.
Old 02-15-2013, 07:57 PM
Mike94ZLT1's Avatar
https://ls1tech.com/forums/generatio...m-failure.html
Old 02-16-2013, 06:04 PM
garygnu's Avatar
how do the jesels cost for a ls1.I like the design of yella terra.
Old 02-16-2013, 06:21 PM
Tainted's Avatar
For every one jesel failire there are probably 25+ yella terra failires along with all the other 'budget' ones.
Jesels or t&d shaftmount, otherwise stay stock with trunion upgrade.
Oh and the jesels are comparables are $1000+
Old 02-16-2013, 09:27 PM
Rise of the Phoenix's Avatar
I've heard this too, but do you still have to run the shim kit even with the PM guides?
Old 02-16-2013, 11:44 PM
garygnu's Avatar
I wouldn't consider YT rockers budget ,but they are $600 less the jesel.I see alot more HS rocker problems,then YT failures..I believe the YT rockers do ok in Aussie circle track racing.the YT rockers are 2 rockers mounted on 1 shaft,looks more stable then a HS rocker .ask Tony M,but I believe I saw YT rockers on Tonys lastest ls 454 build.
Old 02-17-2013, 05:32 AM
I don't believe so. I'm going to verify this when i talk to TEA. I'm thinking of having them set me up the 215 TFS heads. They are local to me, so i decided to use them instead of waiting a couple months from other vendors, even if i have my stockers ported.
Old 02-17-2013, 06:50 AM
Please post up once you find out for sure. I know Thunder Racing sells a shim kit/pushrods for the TFS heads for guys using stock rockers. Anyone else have them?
Old 02-17-2013, 07:48 AM
The Scammer Hammer
dr_whigham's Avatar
You still have to check for correct wipe. Some need them, some don't.
Old 02-17-2013, 07:52 AM
HioSSilver's Avatar
make sure you replace trick flows **** valvespring.
Old 02-17-2013, 09:13 AM
Tainted's Avatar
I want to add, even if you have powdered steel guides on the TFS heads, it will VOID YOUR WARRANTY IF YOU DONT HAVE TRUE ROLLER ROCKERS
Old 02-17-2013, 11:09 AM
MikeFSKSpeed's Avatar
Scorpions/Comps for the stud mounts, and T&D For Shaft Mounts
Old 02-17-2013, 04:18 PM
TEA will be using a different spring package, I wouldn't be buying these off the shelf.
Old 02-17-2013, 04:36 PM
garygnu's Avatar
I hadn't herd about bad springs on TFS heads ,maybe I will have mine tested .
Quick Reply: Most reliable rocker arm for trick flow heads
