Ls1 oil pan bolt hole stripped questions
Old 02-19-2013, 08:24 PM
Burken01's Avatar
Default Ls1 oil pan bolt hole stripped questions
So I'm torquing down my oil pan and 2 bolts holes in the block are stripped, I know they are supposed to be torqued down to 18 ft lbs....
Well one bolt holds till about 5-10 lb's and the other bolt barely holds but it will thread a few rotations and then its loose again..
circled in red is the 2 bolts that are stripped, I was told by somebody that since the bolts circled in blue are sandwiching the stripped bolts that it should be ok and to just put some red loctite on the stripped bolts and tighten them as much as they can go...
what are some of your guy's thoughts on this, I know there's "helicoil" kits... but are they easy to use and what size kit would I need?
I know I should helicoil it but if people on here have went through a similar experience then I should be fine.. I mean all the other bolts torqued down perfectly..
Old 02-19-2013, 08:39 PM
Italianjoe1's Avatar
The LS pans are structural, I wouldn't rely on loctite to hold stripped bolts in properly.
Heli-coils work well, if you don't want to figure it out i'd suggest finding someone locally with some experience doing them and just repairing them, will be much better in the end.
You will have to remove the pan to do the repair properly though. Good luck.
Old 02-19-2013, 08:52 PM
Burken01's Avatar
yes I realize that, I have the engine on a stand so it shouldn't be too bad... ehh I keep running into little problems I'm running out of energy and getting a little desperate
Im researching helicoil kits and will buy one tommorow and get it done...
Time to drill into my block
Old 02-20-2013, 12:38 AM
gMAG's Avatar
I used this M8 X 1.25 Helicoil kit to repair the stripped oilpan bolt hole.
You need only 18lbs of holding power.
They might be found elsewhere for cheaper, or possibly free shipping.
Before installing the helicoil, you'll want to verify the correct depth to sink it, since it is shorter than the depth of the hole.
Simple to do, & they hold perfectly!
http://www.ebay.com/itm/Helicoil-554...27b0e4&vxp=mtr
Post #20 confirms oilpan to block bolt size.
https://ls1tech.com/forums/conversio...-buy-them.html
Old 02-20-2013, 12:43 AM
Burken01's Avatar
Originally Posted by gMAG
I used this M8X 1.25 Helicoil kit to repair the stripped oilpan bolt hole.
You'll want to verify the correct depth to sink the helicoil, since the helicoil is not exactly the same length as the depth of the hole.
what size drill bit did you use to drill the hole before you used the helicoil tap set...?
Old 02-20-2013, 12:50 AM
gMAG's Avatar
The correct bit size is 21/64".
If you buy the kit, the bit, the driver, & the helicoils are included.
FWIW, I've just noticed that they are distributed by Emhart Corp, right here in CT...made in China, of course.
Old 02-20-2013, 12:55 AM
Burken01's Avatar
good ole mad in china lol...
thanks for the info, from what i see the hardest part will be drilling completely straight....
Old 02-20-2013, 01:10 AM
gMAG's Avatar
In the event you don't drill perfectly straight, the bolt will still hold, just fine. It's really about the bolt firming the oilpan surface against the engine.
Old 02-20-2013, 01:36 AM
Burken01's Avatar
so either way ill be fine
Im glad cuz I wasnt going to get any sleep till i researched helicoils
now I can't wait for 7am to come, hurry up earth!
Quick Reply: Ls1 oil pan bolt hole stripped questions
