pushrod help
pushrod help
First off I bent a couple of my stock p-rods and I was wondering if 4.375 is a good stock replacement. I've searched on here and finding that 7.400 is stock length but other guys measured them and came up with them being a little shorter than 7.400 I'm pretty stumped I don't have the correct tool to measure mine besides a ruler and tape measure. According to those its a little under 7.400 any help its my dd and my other car is down too.
If you have doubts order a Comp Cams Pushrod checker ($20) to verify. It's better to know prior to ordering then guessing.
http://www.ws6project.com/user_stor/...oducts_id=4634
You may have some confusion on how long due to the several factors that determine the length.
OEM length is 7.4"
If you have your heads milled, install a new cam, lifters, or new set of heads, even gasket height add all of them together and they will effect the outcome of push rod length.
The checker I mention above is the only true way to know for certain. I know from recent experience. I had to pay for 2 sets of push rods.
OEM length is 7.4"
