rod bolt help
Not saying this works without problems on everones engine but, I installed arp rod bolts on my ls1 when I had the short block rebuilt and had no problems. When I done mine the engine was first put together using the factory bolts then I replaced one rod bolt at a time torqing to spec. Just make sure you get the correct bolts ( cracked cap arp bolts) and be sure to pull the little sleeve that's around the bolt out of the cap
