cam for 36lb injectors
Old 02-23-2013, 11:45 AM
krzy_z's Avatar
Default cam for 36lb injectors
so Im not sure were i should post this but i had bought a intake setup and it has 36lb injectors, im goin to be using this on my 5.3 swap im doing, its nothing crazy just goin to be kinda like a dd heads are stock and im running short headers and auto trans I was thinking of running a ls6 cam but not sure if i should go bigger or what the I should use for the injecotor size.
by the way the motor is goin in a 84 s10 blazer
Old 02-23-2013, 01:20 PM
farmington's Avatar
those injectors are a little big for what you need. You should be able to buy some 26-28 pounders and then sell your 36's and end up with some money to boot.
Quick Reply: cam for 36lb injectors
