Is my ladies Z28 toast?
She bought it a few months ago it runs fine she bought it with the gauge like this is it a bad gauge or motor? I found one piece of metal on the oil drain plug looked like a finger nail but obviously metal.
http://static.photobucket.com/player.../VIDEO0008.mp4
I would start with replacing the oil pressure sending unit. Simple fix, not expensive, and it’s not uncommon for them to go bad.
Do you happen to have any pics of the piece of metal you found?
You do not need to drop the pan, you just need to lower it. Remove your timing cover, the pump is on the crank snout on the front of the engine. Gently raise your jack up to the oil pan, remove all the bolts, then slowly lower it. Just be careful removing the pickup tube bolt, if you drop it then you will need to drop the pan completely. Also be careful tightening the oil pan bolts, anything past snug and you will strip them in an instant.
