head studs for 5.3
Old 02-28-2013, 03:59 PM
LQnotch's Avatar
Default head studs for 5.3
when buying them.. there are two styles for gen 3 and gen 4 correct? what changes the blocks or heads? i have a 99 block and an 05 or newer set of heads and not sure which ones to get.
any info would be appreciated thanks
Old 02-28-2013, 04:23 PM
jrpimp00's Avatar
Its the block that changes.
Old 02-28-2013, 05:14 PM
LS1MCSS's Avatar
Here's one sure way to always figure out which set you need. Stick a long skinny screw driver in the bolt holes and see if the big bolt holes are all the same depth.
The following users liked this post:
rabies (03-04-2020)
Old 02-28-2013, 07:20 PM
NVR_SPDS's Avatar
Like was said, the blocks are different. The mounting locations on the heads are all the same. 97-03 had the different length, and 04-later have all the same length.
You can get anything thin and long, and check bolt hole depth just to be sure.
rabies (03-04-2020)
Old 02-28-2013, 09:41 PM
LQnotch's Avatar
thanks alot guys
Old 03-01-2013, 06:59 PM
Blazeracer's Avatar
In particular, the outer two bolts on the upper row of HEAD bolts are a shorter than the other ten bolts. This excludes the top of of bolts above the lifters. Head bolts only, or studs if your running ARP's
Quick Reply: head studs for 5.3
