how much will my gas mpg suffer with this cam and stall?
Old 03-05-2013, 08:18 AM
usnfenix's Avatar
Default how much will my gas mpg suffer with this cam and stall?
so looking at a t/a to replace the 01 ss i used to have, only concern is i will dd the car and the car is equipped with the following not so gas friendly mods.
any guesses as to gas mpg? it has many other mods but these are the ones that will cause gas mpg to suffer. thanks for input
228 230dur /598 600lift, 112+2 custom grind cam
4.11 gears
yank 3800 stall
Old 03-05-2013, 09:26 AM
Tainted's Avatar
probably lose 2-3 in city, not much on the highway since you will be in overdrive and the converter will be locked
Old 03-05-2013, 09:27 AM
96capricemgr's Avatar
HP potential doesn't hurt mileage much, USING that potential does.
If tuned well and driven reasonably you wont lose much
Old 03-05-2013, 10:28 AM
redtan's Avatar
You can tune all you want, the stall is still going to kick his but in the city mpg department. Highway not as much.
In the city you might lose 3-4, highway maybe 2-3 or so depending on the tune.
Quick Reply: how much will my gas mpg suffer with this cam and stall?
