What oil pump with cam swap
im about to swap a melling stock volume high pressure one real soon. as long as you dont get the crappy 1998-2000 oem pump is fine. The stock ones from that year are known to fail. Hence the swap ill be doing
I too am a Melling oil pump fan! They are a very high quality replacement......and I happen to keep their oil pumps in stock!!
Melling states that engines with increased bearing clearance may require the HV/HP pump.
Here is George Richmond of Melling discussing the differences of the LS based oil pumps they offer. Go Melling!
2) Melling It's a High quality pump and it's like extra insurance so you won't have to go back in the engine and replace it like I did.
3) Not really unless you have low oil level, I have the HV and I have pushed my car to 160 mph and the oil pressure stays pretty good.
