Crank for my LQ9
Old 03-11-2013, 10:57 PM
DieselZ28's Avatar
Default Crank for my LQ9
Is there any reason an LSA crankshaft would not work in an LQ9 block? Building a mild turbo motor and for the price of a forged GM LSA crank I can do without the extra stroke of an aftermarket. And yes I searched but if you type LSA you have to dig through a million cam threads.
Old 03-12-2013, 12:52 AM
conan's Avatar
The stock cast 3.622 crank is good for 1,000+ HP. Unless the LSA crank you are looking at is a bigger stroke, I would save the money and run the crank you have in the LQ9.
Old 03-12-2013, 05:03 AM
DieselZ28's Avatar
Well that's just it. It's a bare virgin block. Brand new never used so I do have a crankshaft yet. It's 500 and some change. Not bad for a forged crank I think.
Old 03-12-2013, 08:21 AM
conan's Avatar
The only problem I see with this crank is it has a 8 bolt pattern for the fly wheel / flex plate. So depending on what transmission you are going to use I would look in to price and availability for those parts in the 8 bolt VS the standard 6 bolt before you buy.
Quick Reply: Crank for my LQ9
