Where did my oil pressure go?
so i went to start my Z today for the first time in about a month or so and i fired her up she was running for maybe 3 seconds when i looked at the oil pressure gauge and it was pegged on 0. I quickly shut the car off. The car has always had good oil pressure in the past, im at a lose as to why all the sudden it is reading 0? I was thinking that maybe its the gauge or sending unit it possibly, because it does something a little funky. when the key is OFF the gauge would creep up a little to maybe 5-10psi ish, and then when you turned the key to run the needle dropped back to 0? does this seem odd to anyone?
I had the exact same thing happen on mine and i had to replace the oil pump. It was running perfectly, then dropped it off at a mechanics for about a month, and then almost no oil pressure.
Maybe yours could just be the spring inside the oil pump. That way you dont have to replace the whole thing.
