Are Comp Cams Trunions Worth it?
I know this has been covered a bunch, and I read a bunch of threads on them, but I'm still not sure. I'm running a torquer V3 and I know that the LSK lobes and high lift are hard on the valve train. I would hate to have needle bearings let loose through the motor, but if its not necessary, I would just save the $150 to put towards a FAST? Plus, the place that is dyno tuning my car says that they never use them and they could cause more problems than they are worth, and I value their opinion because they are very trustworthy place. So what does everyone thing?
What cam lobes and springs you have? I think your problem is there, not the Comp upgrade. If you are breaking parts you have an unstable valve train, and you are beating the crap out of your parts. Just like the LS7 lifter failure threads, the lifter is not the problem, its unstable valve train. The lifter just happens to be the part that takes the blame, because it fails first.
Straight from that catalog
The Comp Trunion upgrade is worth the money, I am running them in my new build.
http://www.briantooleyracing.com/com...nnion-kit.html
The LSK Series has been designed with enhanced characteristics from our latest professional drag racing profiles. These
have excellent ramp quickness. They are VERY hard on parts and not generally recommended in street applications!
Like said above; either you have an unstable valvetrain, or the trunion upgrade kit was installed wrong. Possibly forgot to install all 32 c clips? Haha...
In your thread you said one c-clip snapped off and another had a crack. Also some of the rockers had worn metal on the underside and only on one side of the trunion where they ride in the bearing which says to me factory defects in metal preparedness and hardness practices. I haven't seen another case like yours. IMO it wasn't anything you did to cause the wear on the nderside and as for the c-clip, in the picture you show where the c-clip portion is snapped off the bearing isn't pressed in all the way and it is supposed to be flush which could cause excessive side to side play maybe stressing the retaining clip too much.
FYI, Lunati does offer Stock rockers with their own trunion upgrade kit(85427-16) for under $300, I'm not sure if they offer their trunion upgrade minus the rockers or not.
Summit also offers a trunion upgrade kit(SME-143002) for the factory rockers which has larger /beefier retainer clip than the CompCam kit, and the summit kit is only $100..
