Lq4 piston help!
Lq4 piston help!
I'm boring my block .030 over and want to put a set of forged piston in with the stock rods. I also want to keep the stock compression witch is 9.4-1. I'm having trouble finding a set with 945 pin OD. Any help is much appreciated.
Why use stock rods? The PMRs aren't as strong as budget aftermarket rods. Based on your compression, I'd imagine you will be going boost. So stock rods don't make sense IMO.
