Is there a place I can get TFS 220 heads with better valve springs
Is there a shop or vendor on here that sells the TFS as cast heads with upgraded valve springs? Not really sure what Trick Flow was thinking putting valve springs that are only good to .600 lift in these things.
I do not want them milled I need 64+ cc combustion chamber.
I'd get the PRC as cast heads but it doesn't seem like there is much info out there on them, which is making me think people aren't buying them.
The Scammer Hammer
I'd go through Brian Tooley @ Brian Tooley Racing if I was you. Guy's AWESOME to talk to, and will ensure you get everything you need, as well as optimizing your combo.
Brian Tooley was the creator and owner of TEA...
http://www.briantooleyracing.com/
