HEELLLPPP!!!!! oil pump replacement
getting ready to tackle my oil pump. car has 140k on it and the gauge bounces on idle alittle above 20 psi and never gets higher the 50 psi. so as a precaution im going to do my oil pump. plus install a autometer oil press. gauge. few questions for you guys. will the fatter autometer sending unit fit behind the intake or do i need and 2" extension to get it up and away from the intake. second question is there a special tool designed to take off are harmonic balancers or can a regular style one work?
There's a 3 jaw puller specifically designed for ls engines. Go with that. I got one from harbor freight and it sucked. My personal recommendation on an oil pump would be either the synergy or high flow melling oil pump. Don't go with the ported version. Imo a waste of money.
you can rent the 3 jaw puller from a local auto parts store. be sure to put the jaws on the inside of the balancer, turn it and lock it on the grove thing. you will see what im talking bout when u look at it. you will need to get a longer crank bolt to put the balancer on.
read this how too. it really helped me out. and be careful with the oil pimp tube pickup bolt.
http://www.ls1howto.com/index.php?article=4
Not much room for a 'fatter' sender. Check this link - the 6th picture down shows the LS1 sender area with manifold. Don't forget - you need a pulley install tool like this (shameless plug): install tool
The auto-meter sender will need the adapter to fit in the engine, plus you will need an NPT extension with an angle. I have one on my LS.
50 PSI sound normal to me. Mine will idle about 40 hot, go to about 50-60 driving around about 2K RPMS.
trucks are easier because the pickup tube bolts to the higher hole on the pump. on the cars, the pickup tube is on the lower hole and you have to lower the pan to get to it. only need to unbolt the front ones, and loosen the back ones. the bolts by the motor mounts suck to get to.
