Head swap
What year block are you putting the heads on? That will tell you which type headbolts you will need series 1 has short and long bolts, series 2 has all the same length. Unless you ARP bolts never reuse headbolts.
are you just doing the heads, no cam swap? If heads only you will need head gaskets, GM MLS , Cometic etc. New GM head bolts or ARP bolts and I would recommend an ARP M11 thread chaser to clean the head bolt threads in the block, very critical step to spend time on and get right. I would also go ahead and get a new set of lifters and lifter trays (4X) while your at it. Use WD40 and a green SOS pad to clean the block.
great DIY head swap article
https://ls1tech.com/forums/generatio...-corvette.html
Dont forget a spring compressor if your new heads dont already come assembled.
