Made 400rwhp with a hotcam
M6 TA, al FW, 25% UD, ls6 intake, CNC P&P 806's milled .035, 1.8 al roller tips, AR LT's to 3" true duals with single chambers. & all free mods and tune. Made 409/401 with a damn hotcam. The added lift and badass heads helped
Hotcam cuz of idle and gas mileage and driveability. Its a hell of a streetcar. And the torque is AMAZING. I beat the **** out of a guy with an ms4 and 243's from a 20 roll. He still doesnt believe me that its a hotcam. I also have an electric cutout and electric water pump. OH amd im getting RIGHT at 29-31 mpg at 65mph with my 3:42's!! Not my daily either. Just a fun all around car
Hot Cam a true LS1 designed cam or an LT-1 knockoff? I recall there was a LT-1 Hot Cam. I think it would be interesting to deconstruct the cam and build one on modern lobes and valve height. Imagine the power difference compared to the GM old tech.
These are as close as you'll get in shelf grinds.
Howard Cams has the #197245-12, which is a 219/228 112lsa with aggressive lobes and the same .525" lift as the hot cam.
I'd get a adjust timing chain/ sprocket set so you retard the cam and set the ICL to 112, if you so desire.
Compcams 219/227/ 112lsa w/lsl lobes and get an adjust timing chain/ sprocket set if you want to retard the cam and set the ICL to 112.
http://www.ws6project.com/user_stor/...lsa-4-8l-5-3l/
The lunati 222/228/113lsa would be nice choice for something fairly similar.
http://www.ws6project.com/user_stor/...oducts_id=4627
