Pro's & Cons for a 370ci budget build
Old 04-29-2013, 03:29 PM
smws6ta's Avatar
Default Pro's & Cons for a 370ci budget build
Cam across a couple of 370ci builds got me thinking.
What are the pro's & cons of doing this? I would love to do a 408ci build but just not going to be able to do it just yet.
I have a LQ4 short block & stock 243 heads (not milled)
Currently looking at Tick's Polluter stage 3 for cam.
Old 04-30-2013, 10:10 AM
Super Hulk Smash
JakeFusion's Avatar
370 vs 346 - 370 has more bore and can make more power; has a stronger block, but it's heavier and can't take as much timing/compression due to the iron block
370 vs 408 - 370 is cheaper but 408 is stronger and makes more power with more stroke
If you're boosting an engine or running lots of nitrous, 370s end up being a good balance between strength and cost effectiveness. Also, I prefer to run a shorter stroke in boost or nitrous applications in order to use a stronger piston with a thicker ringland. The stock GM crank is good to 1k HP, so for most folks, a 370 is plenty.
All motor, 370s are good as well. 6L with the same heads/cam as a 346 usually make another 10-15HP and a good 20-30ft/lbs more.
Old 04-30-2013, 10:41 AM
alans02z's Avatar
I have never heard of timing and compression having a limit with an iron block verses an aluminum one. Care to eloborate?
Weight is the only con. Everything else, pro
Old 04-30-2013, 12:03 PM
Super Hulk Smash
JakeFusion's Avatar
Yeah, try to run as much timing in an iron block combo with similar compression to an all aluminum motor. You can't. I've never seen it. You always have to pull 3-5 degrees.
That's why must engine builders recommend slightly lower compression on the iron block builds given all other factors being the same (compression, dynamic compression, plugs used, etc.)
Old 04-30-2013, 12:22 PM
alans02z's Avatar
I have.
Thats why Im asking you to eloborate and explain why. All you really did was say you cant.
Old 04-30-2013, 01:37 PM
windmill's Avatar
I better lower my timing in my mustang then,,, im running 38 deg right now with a carb,,,,
Old 04-30-2013, 02:56 PM
PREDATOR-Z's Avatar
Jake, combustion happens between sleeve walls, piston and head chamber. Where does the block play a role?
I've run LS2 and LQ block in same configuration on same tune with same compression and cam. No difference in my combos was seen. Same output.
Old 04-30-2013, 03:08 PM
camaroz98's Avatar
i run the same in my 84 camaro no true problems besides wont run for **** on and bit a pump gas. $6 a gallon for 100+oct is killing me
Old 04-30-2013, 07:34 PM
windmill's Avatar
im changing to e85 fuel,, going to spray it with 200 too.
Old 04-30-2013, 09:30 PM
redtan's Avatar
I've never heard of it either. What does block composition have anything to do with the amount of timing and compression you can run?
Heck, I would imagine that a stronger iron block would be able to take MORE compression and timing than a soft aluminum block with thin iron liners...
smws6ta's Avatar
Thanks guys...looking to see if I can budget it. After talking with Martin I think I'll just save the money for a 408 build later....
Old 04-30-2013, 10:10 PM
88mmrocket's Avatar
So what, you think an aluminum block has aluminum sleeves in it to? That's why it can take more compression?! GTFOH! It has cast iron cylinder liners in it!
That is the funniest thing I have read yet.
OP, what are your goals for this motor? It you want budget, pick up a good set of used rods, some nice forged pistons and use the stock crank. Put a good cam/spring package in it and let it eat.
Old 05-01-2013, 01:06 PM
alans02z's Avatar
Did you bow out of this because you have no answer for the **** your spewing or what?
Old 05-01-2013, 04:48 PM
smws6ta's Avatar
I made this thread before I talked it over with Martin @Tick. I told him what I was doing and my options. Stay as a 364 or do a 370. He made some good points that in doing a 370 build now and in a couple of yrs a 408, I'd just be saving on machine costs in the long run but adding more to my 408 build later on because I may or may not be able to recoup the pistons & rods for the 370 build when I decided to do a 408 build.
So I'm going to go with his Polluter stage 3 and BTR valves to go with the 243 heads and LQ4 short block that will have LS2 pistons I picked up. I still want it street drivable (such a variable term) but want to have some fun too.
Having a shop (Seems to have a good rep from the LS community here and is also a race shop, might mean I'm low priority since it's race season here)
(1) check the block (magnaflux) + hot tank it $60 + cost of cam bearings
(2) resize the rods for arp bolts $75-$80
(3) balance the crank and rods $225
(4) have them get it to a short block. $200 + crank/rod bearings
Old 05-01-2013, 06:35 PM
88mmrocket's Avatar
Glad you are not touching the bore size....yet! Remember this isn't a gen 1 sbc or sbc so once you bore it .030" and hurt it you better hope that it doesn't eat a cylinder wall! By that time you better be looking for another block IMO. Now my gen1 sbc, hell .030" is the starting bore!
I am building a motor to go into the 4.8-.9x range on a stock block. All i did to my own block was go .005" over and called it good just because the block was perfect. No need in going to what some say is the max for these block right off the bat. Plus, these pistons were actually cheaper than going .030" over!!! Lol!
Good luck with it!
Old 05-02-2013, 12:15 AM
Super Hulk Smash
JakeFusion's Avatar
Originally Posted by alans02z
I have.
I don't have a reason. Maybe our gas sucks. It was also like 6 years ago when I was around cars other than my own and tuning/dyno testing was done. But I do remember it being an issue with iron blocks that we couldn't figure out.
As Pred said, the combustion process happens outside of the block. So, that's why we didn't know. It wasn't heatsoak, but that was our guess being we're in the FL humidity.
Anyway it's based on experience. Not internet guru bullshit.
With that, I'll be the first to admit when I'm wrong, so maybe I'm remembering it wrong. But I've always stayed away from iron blocks because of that, rightly or wrongly.
Quick Reply: Pro's & Cons for a 370ci budget build
