okay to remove main/rod bearings then reuse?
Old 04-30-2013, 08:16 PM
RotaryResurrection's Avatar
Default okay to remove main/rod bearings then reuse?
I have an LS6 engine that had a low oil pressure issue soon after a cam install. I've pulled the oil pan and found tiny metal particles etc. so I know a bearing is screwed somewhere. I want to check the main and rod bearings so I can decide whether to pull the whole engine apart or just pull the cam itself out.
I have ARP rod bolts and stock main fasteners. Is it okay to unbolt each one by one and remove it to check for damage/wear, then reinstall it in the same position? I assume the ARP fasteners are reusable; I suspect the main fasteners are not, can anyone confirm?
TIA
Old 04-30-2013, 09:07 PM
badazz81z28's Avatar
I'm pretty sure the mains are TTY bolts. You should have no problem removing main caps and re-installing them for inspection. Do you have the engine removed? I would swap out all the bearings anyways, get the crank polished etc. If there is trash in the cam bearings, the mains most likely have imbedded crap too.
The following users liked this post:
Homer_Simpson (11-20-2021)
Old 04-30-2013, 09:39 PM
So far I pulled one rod cap off and the bearing looks almost perfect (to me).
Old 05-01-2013, 01:13 AM
PREDATOR-Z's Avatar
You guys should not mess with things you do not understand. Gosh I'm tired of seeing inexperienced people butchering these motors.
Bearings are seated and should not be removed and reinstalled. And no even if some apprentice did it and thinks it was fine, it is not proper protocol/procedure.
lawrenq (01-08-2021)
Old 05-01-2013, 01:50 AM
Wow...I wasn't expecting such a "hardass" reply.
However, thanks for the information regardless. Perhaps you'd be so "kind" as to inform the rest of us as to why this is a totally improper procedure...for those of us who like to understand the "why" behind the "yes or no". Do the bearing halves/caps change shape or size after tension is taken off the bolts?
Old 05-01-2013, 06:15 AM
PREDATOR-Z's Avatar
Not "hard ***", more like "honest" opinion. See, I used to do the same (with SBC)s. I've ruined more parts than I care to admit, but I was willing to modify my "under the tree mechanic" attitude and actually learn/practice proper ways of fiddling with my motors.
Certain procedures have to be followed in order to properly assemble/disassemble mechanical parts.
Shortcuts only lead to more expense and weak returns.
Yes, bearings "seat" themselves and will change shape if removed. It would be pure luck if you could reinstall them in exactly the same spot as they were before. It just doesn't work that way and can result in premature death of your assembly.
The same applies to "what push-rod should I use". It is not on the net that the answer is found, one has to measure; that is the only way.
2 identical setups but different blocks will not necessarily mean same length push-rods.
Yet this question pops out over and over again.
My apologies if my style is sometimes too forward and direct. I lack diplomacy. We all have weaknesses. That is one of mine.
billymgb1000 (11-12-2020)
Old 05-01-2013, 07:15 AM
ckpitt55's Avatar
Originally Posted by predator-z
not "hard ***", more like "honest" opinion. See, i used to do the same (with sbc)s. I've ruined more parts than i care to admit, but i was willing to modify my "under the tree mechanic" attitude and actually learn/practice proper ways of fiddling with my motors.
the same applies to "what push-rod should i use". It is not on the net that the answer is found, one has to measure; that is the only way.
my apologies if my style is sometimes too forward and direct. I lack diplomacy. We all have weaknesses. That is one of mine.
+1000
Old 05-01-2013, 08:28 AM
The OP is just taking the caps off....Why would you pull the bearings out?
Old 05-01-2013, 09:08 AM
PREDATOR-Z's Avatar
And the bearing is on the cap.
Old 05-01-2013, 09:51 AM
greenvortec97's Avatar
Are you serious?
Old 05-01-2013, 09:54 AM
ss performance's Avatar
Bearings are not that expensive so why risk reusing them?
Old 05-01-2013, 10:52 AM
ckpitt55's Avatar
the caps are also not doweled. this means that even though the bolt holes line up they will reseat differently every time you take them off and put them back on.
Old 05-01-2013, 10:58 AM
lt1pwr1's Avatar
You do realize that some motors call for removing the rear main bearing cap when replacing the rear main seal? For example, Jeep 4.0L engines require this. In many cases you have to loosen all the main caps to get the seal out so I see no issue in doing what the OP is asking about.
HOWEVER, you must not switch them around. Make sure they go back the exact position they came out and torque them properly.
I did a rear main seal on a Jeep Wrangler following that service information and 30K miles later it still has great oil pressure.
Old 05-01-2013, 11:29 AM
ckpitt55's Avatar
do you drive the jeep the same way you drive the trans am? on which one do you think bearing alignment / clearances are more critical?
Old 05-01-2013, 11:53 AM
KCS
Moderator
KCS's Avatar
So, in what way does the bearing "changing shape" hurt?
Old 05-01-2013, 11:54 AM
As far as the rods, I was under the impression that they were cracked halves, and thus each rod and cap had unique fitment to one another. So it seems like the cracked cast pattern of material would align itself and seat the bearing/cap exactly where it was before.
So, I guess the consensus that I'm reading here is that it's not okay to remove a cap here and there and check the bearing and crank condition, so anytime a single bearing anywhere in the engine goes awry to any degree, you are required to assume that every bearing is damaged, do a complete teardown of the engine, and replace them all.
Here is another question for those who "know best". I build rotary engines, and in our world, used bearings are generally superior to new ones when their condition allows reuse, because age and heat cycles strengthen the old bearings and bond them in place so that they are unlikely to spin. Once you replace an older bearing with a new one in those engines, you increase the chances of spinning it in the future, as it is not as well bonded to the parts they are installed with. Is that also the case with these engines? I am guessing based on your responses that it is not the case, and people just throw in new bearings on a whim.
It seems from my research on this forum that it is not uncommon to spin or walk cam bearings for no apparent reason, and that is most likely what has happened to me. I just changed the cam in this engine before swapping it in and putting 50 miles on it when oil pressure dropped by half. In my mind, it seems like, if it is so easy for original bearings to walk or spin, it would be even more likely for replacements to do so.
Old 05-01-2013, 11:56 AM
Old School Heavy
speedtigger's Avatar
Guys, bearings can be removed and re-used without problems if care is taken. I have been at this for 25 years on all different kinds of engines and it is absolutely fine AS LONG AS CARE IS TAKEN.
Now whether or not you SHOULD do it is another story. If the bearing material and/or the crankshaft is grooved (slight surface damage from dirt and contamination), the crankshaft should be polished at a machine shop or resized and new bearings installed.
As for R&I of existing bearings, keep in mind that the bearing shells fit into the journals with a bit of preload. So, removing them requires some touch. If you bend the bearing shell slightly during removal and destroy this preload, the bearing is junk and should not be re-used. Bearings are very delicate and precision pieces and great care needs to be taken not to distort the shell, burr the edge or damage the soft surface materials. Make sure the bearing shell goes back in the same journal that it was removed from. Do not swap them around. If you lose track of what journal they were in, replace them.
In addition, this operation must be absolutely contaminant free. This goes for installing new bearings too. The journals, caps, bearings and crank must be absolutely spotless. One tiny piece of sand between the bearing and it's journal will stop the bearing from fully seating in the journal. This will reduce the crank to bearing clearance and hinder heat transfer. So think clean, clean, clean. Once the bearing is installed back in the journal, lubricate the bearing and the crank surface with assembly lube. Do not lubricate the backs of the bearings where they mate with the rod and block journal surfaces.
Check any bearing you remove for size. Unless you built the engine yourself, there is always a chance that the crank has been turned. If you replace the bearings, you must determine if they are standard or and under sized bearing like .010, .020 etc.
If you are a noob, find somebody with experience and have them inspect the bearings before you re-use them.
Old 05-01-2013, 12:10 PM
ckpitt55's Avatar
I'm not arguing that it can't be done, but it is certainly the more conservative approach to start fresh with new bearings especially if you're not sure of what you have.
As far as cam bearings spinning, check out Loctite 640 sleeve retaining compound. It's a high temp, high strength adhesive that is resistant to engine oil. Could help to add some insurance onto that press fit.
http://www.all-spec.com/downloads/lo...31_120209s.pdf
3rdCoastPowerSports's Avatar
What was the question again?
why would you not spend an additional $150 bucks and replace the rod and main bearings while you have it apart? $150 now for peice of mind vs the labor to pull it back out, tear it down, machine what needs to be machined then buy new bearing and put it back together and re install. No way man
Old 05-01-2013, 12:54 PM
The point is, it's not apart. It's actually still in the car, although I most likely will have to remove it to get the crank pulley off.
I suspect I've spun a cam bearing since that's the only thing that was recently changed on the motor and now I have reduced oil pressure and fine metal particles in the oil pan, but I'm not sure yet.
Assuming that I pull the cam, find a bad bearing, and replace one or all the cam bearings, I would want to leave the heads and rotating assembly together. Put cam bearings and cam back in and run it.
I only wanted to check a couple of mains and rods to be sure they weren't damaged.
The one rod cap I've pulled off looks great to me.
What you're suggesting is a full teardown and rebuild, as far as I can tell. The motor only has 33k on a rebuild, so I don't really want to do that.
Quick Reply: okay to remove main/rod bearings then reuse?
