Pics Of My Advanced Induction Dart/RHS 223cc Heads/Build Thread
#261
I wish you were closer, I'd let you use my QTP's as an open header test just to see if that truly is the issue. Is this still a MAF tune? What's the timing like? But before you go crazy, most stock M6 LS2 GTO's put about 350 down IIRC, so theres 20 there.
#262
did you ever get the afr readings?
On the street we tried 29deg and it pulled 2deg back out,
out of 5 hits we seen 1 hit pull timing at 28deg so i think thats about as far as i would like to push it for timing, hell may pull a deg or 2 it may like it.
But would like to know what the afr where
#263
Super Hulk Smash
I'm offering up why he's making lower torque than we all expect with a 41 IVC and 11.5:1 CR to make.
Hell Mamo will even tell you that and that's why he generally specs 4 degrees variance Int/Exh with only 1 degree of advance on fairly wide LSAs. The heads perform better within those parameters than with a more conventional split or higher overlap. So if you put a cam with 15 degrees of overlap and a narrower split would it make the same power out of the 365? The wealth of dynos out there suggest it would and it'd drive a lot nicer too.
The G5X3/AFR205 combo made killer power, albeit with headers designed for velocity, but that had 15 degrees of overlap, but a wider split that was aided significantly by the LG Pro headers design with the right merge and extremely long primaries to maximize the exhaust port qualities of the AFR 205. Generally those made 490-500rwhp/440-450rwtq. Out of a 346.
#264
Well crap, tuning without a wide band is like shooting fish in a barrel with a rubber band gun. Sounds like it needs a lot more fuel for sure though. What are the knock sensors set at?
#265
I just texted him for the air/fuel readings.
#267
The Scammer Hammer
Holy ****.
Yeah, I read everyone else's replies...
Look. You need to get to a tuner that can TUNE your car on a dyno. This dyno variance **** is exactly that. Yeah, mustang vs DynoJet has merit, but that's it. I've put down identical #'s on Geoff's dyno 8 months apart. Here in southern Louisiana that's a big frickin deal.
Brother, please, make the drive here to Geoff @ EPS. Don't worry about room and board. I have MORE THAN ENOUGH room for you and your family, and you won't even feel like you're putting us out. Trust me.
#268
Holy ****.
#270
Holy ****.
#271
Holy ****.
Well, I've got the dyno part taken care of and I've got confidence that my tuner can get this thing dialed in on the rollers. I know these heads are bad *** and flow a **** ton of air, so I don't think it's that. Hell, Phil told me several times that these heads flow more and will produce more HP than the ported 243's and the flow chart reflects that. We're going to get this thing dialed in and see what it does and how much it picks up.
Thanks for not giving me too hard of a time. I know I talked a lot of **** and said I'd be right there with you in terms of power, but I'm not even close. It will get fixed though.
#274
I really think you should run another car with a similar setup/numbers you should be making and see how it performs.
Dr_Whigham - Its nice to see there are still some good guys out there!
#278
In good weather Ive seen a few LS2 GTO's hit upper 350's and low 360. My buddies with just a tune made 368 on Vengeance's dyno. This is why everyone say's dont rely/get caught up in dyno numbers because they all vary.
SD all the way!! Make sure you relocate your IAT sensor to the front bumper. If it was tuned on the street with a wideband then I dont see you being able to eek out much more on the dyno, unless your street pulls were limited. Its a lot easier on the dyno cuz your not fearing jail time. I'd probably back timing down to 24* total just to get started and see where your at. I like to run less timing down low and ramp it up on the top end (more torque down low). One question cuz I dont see it on your mod list, but is it safe to assume you have more than a stock pump with those 44#'s?
#279
#280
The car was street tuned using a lm1 wide band (yes o2 bung was used) car was running 12.5/12.7 through out the pull with 28deg.
the car is in full SD
we have plenty of 1/4 stretches to do full pulls around here, but yes the dyno is the place to be to finish up the tune.
on the fueling side yes it still has the stock pump in it.... as of the day the car was delivered. (42lbs injectors)
Nathan and i did talk about a new pump when we started this project, and at the time funds where pass depleted..
The tune does reflect the stock pump.. pressure was dropping pretty fast at 6k
but never does the car dip into the 13s on the afr through out the pull....
inless the pump is petering out the afr where good... (a new pump will be installed and the tune will be adjusted b4 the car hits the rollers again)
