does this hole behind the timing cover get a plug?
i was looking at the timing cover and the gasket and it does not look like it will cover it very well and i dont have my old block to see if it had the same hole does it get some kind of plug ??? and if so does anyone know a part number also does anyone know the part number to the little plastic barbell that goes on the back of the block i lost mine.
1 Post
Yep, looks like a tiny freeze plug that taps in there with a small socket and smeared with a bit of rtv... Thats you're oil galley... All the way back is a tiny plunger plug on that one... Look back behind there and see if it's open or has a off-white plug in it currently...
I'll look harder later but this here is the general idea.. http://www.ebay.com/itm/LS1-LS2-LS6-LS3-LQ4-LQ9-Engine-Block-Plug-Kit-COOLANT-OIL-GM-/130902231125?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7a618855&vxp=mtr
its the little one on the bottom left...
so the tiny plunger in the top of the picture is in the same passage just the back of the motor and i should be able to see it back there without taking off the cover
