comp cam spring compressor.....JUNK
Old 05-12-2013, 05:42 AM
Matt GMC's Avatar
Default comp cam spring compressor.....JUNK
Just finshed with 2000 trans am, put cam, springs and pushrods in this weekend.
DO NOT, I REPEAT DO NOT get the comp cam double spring compressor. Payed 100.00 buck for it and it does not line up the valve straight threw the spring so you can not get the retainers back on the valve, had to use a screw driver to pry the spring. (not a good thing).
Oh yea by the way I have a comp cam double spring compressor for sale. ha ha. I wouldn't give it to my worst enemy.
Old 05-13-2013, 11:54 AM
'99REDTA's Avatar
I used the same tool I think for my springs and it was my first time doing it, it kinda sucked for awhile because you have to get both sets of keepers to line up but once I started using the screwdriver to line them up it was way easier. I didn't feel like it was that dangerous but was a lot better than the other tool I'd heard of
Old 05-13-2013, 12:13 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
This really isn't the place for this discussion. I am going to move it to Gen III Internal.
Old 05-13-2013, 01:09 PM
The Scammer Hammer
dr_whigham's Avatar
It's not going to migically align itself...
Next time hit it with your purse.
Old 05-13-2013, 01:16 PM
thunderstruck507's Avatar
How much do you want for it?
Old 05-13-2013, 08:25 PM
poltergeist 02's Avatar
BWAAAHHHAHHAAHHA! Very nice!
Old 05-13-2013, 09:01 PM
03Sssnake's Avatar
nearly pissed myself.....
Old 05-13-2013, 09:15 PM
high impact's Avatar
Second in line for price.
Old 05-13-2013, 09:36 PM
CattleAc's Avatar
Is it part# 5462...???
Old 05-14-2013, 11:03 AM
mkvamso's Avatar
Ive used the exact same compressor and didnt have a problem after i swapped the supplied bolts with some that are a little longer.
Old 05-14-2013, 03:30 PM
VandykeT/A's Avatar
I used homemade version of the cheap one on ebay. Just a flat piece of metal with a bolt hole and the horse shoe cut out. Worked pretty good for me and it was free. Just use a screwdriver to keep everything straight.
Old 05-16-2013, 05:34 PM
11 sec. Truck Mod
TIM Z's Avatar
The crane tool does , at least the 4 times I've used it . Guess I was just lucky .
This comp tool is the cheapest piece of **** I've seen , should cost 40$ not 100 , the bolts supplied are inferior strength , the alignment of this tool is terrible , you shouldn't have to use a screwdriver to align it on every spring change .
Maybe next time we can you show us rookies how its done
Old 05-16-2013, 06:25 PM
The Scammer Hammer
dr_whigham's Avatar
No problem. Would you like a video?
Maybe a picture book wrote in crayon would suit your style a bit better?
All jokes aside, I can't use the Crane Compressor... AFR Heads
Old 05-16-2013, 06:42 PM
99Bluz28's Avatar
Why not dr whigham ?
I have the Crane Cams Valve Spring Compressors #99472-1, and that's what I used when I swapped to PAC-1521 valve springs on my AFR 205 heads.
Old 05-16-2013, 07:10 PM
Super Hulk Smash
JakeFusion's Avatar
Instead of a picture book with crayons, I'd prefer a how-to with women in scantily clad clothing doing the work...
Old 05-16-2013, 08:18 PM
The Scammer Hammer
dr_whigham's Avatar
You've gotta grind the tool to make it fit. MeentSS02, another mod on here let me borrow his and it didn't fit. Wasnt even close. That's why I got the Comp. I wasnt going to grind a borrowed tool. I've got no issues with it. I sure as hell don't use a screwdriver to align it though,
https://ls1tech.com/forums/generatio...afr-heads.html
Last paragraph post 1 http://forums.corvetteforum.com/c5-t...up-beware.html
It takes a few tries to get everything aligned, yes. But it's nothing hard or complicated.
Jake, lemme see what I can conjure up about a "scantily clad write-up"
Old 05-16-2013, 09:49 PM
svg210's Avatar
Hey! Its not a purse, its a satchel!
Old 05-16-2013, 11:17 PM
Super Hulk Smash
JakeFusion's Avatar
I know some really hot women at my gym who do fitness competitions. I should get them involved in a "how-to" video when I get my car done.
Quick Reply: comp cam spring compressor.....JUNK
