Critique my build and make sure I've got everything planned out...
Ok so this summer I plan to work two jobs to pay for these mods. That being said, yes, this is budget build.
1999 camaro a4
stock everything, except lid and has lm2 exhaust
136xxx miles
Mods:
TSP 224R cam package 114 lsa
Melling High Volume Oil Pump with new O-Ring
LS2 Timing Kit (chain+sprockets)
Comp-Cams Retro-Fit Trunion Kit
New Front Seal
Tune
Now I can't decide which used intake, ls6 with p/p tb or fast 92/92. $400 seemed like a lot of money for the extra HP that I probably won't feel. I don't really care what number I make on the dyno so that isn't a factor. I just think that it could be used for headers down the road and have a greater effect.
With an engine of this milage are there any other internal modifications/rebuilds I should?
1999 camaro a4
136xxx miles
Mods:
New Front Seal
Tune
Last edited by Z28SLPCAMAROZ28; 05-16-2013 at 06:27 PM. Reason: Updating Build List
i personally wouldn't bother with the shortblock unless you have about $3k extra set aside for all the parts and necessary machine work to get it right.
unless it's burning oil I'd just leave it alone. you could replace the bearings if you want but if you kept up on regular changes and kept your oil clean then I don't think that would be necessary either.
Couple of notes. (I assume you're going through TSP)
1- Melling high volume is cheaper than a ported LS6
2- Could probably just go with an LS2 chain (45 for just chain, 110 for whole set)
3- Gonna need a new front seal
4- Do the trunion upgrade, its pretty cheap, and the stock bearings are crap
If you just get the LS2 chain, you'll save 15 bucks total and get one more item
Ok sounds good... I read on here somewhere that a common thing to do is swap rod bolts while its open? Other than that I was just gonna see if there was anything I was forgetting...
Thanks, I'll add those to my parts list. For the Trunion kit, the only one I found was the Comp Cam Retro-Fit rocker arm kit so I assume that is the kit your talking about?
Does anyone have a good ballpark estimate for how much all this will cost to get installed? I've been quoted at 600 for the cam install and intake install. That was before all the other parts.
And no, I cannot do this myself. I do simple maintenance on the car but internal engine work is where I draw the line.
Thanks
Thanks
Thanks
Thanks
http://ls1howto.com/index.php?article=23
As for the Camshaft swap. There is a lot of things that I just don't trust myself with. I've never worked on engine internals before. If this was any engine other than my LS1 I'd probably try it myself. Unfortunately I don't have any engines to do this with. That is why I'm gonna take it in.
Ya, I've been was going to do that at home when I decide what to go with. I haven't decided whether LT'S>Tru-duals or LT'S>Dual E-Cutouts>Y-Pipe
Ya I have no problem doing exhaust work because I can't seriously mess up the engine doing it. Worse thing I could get is an exhaust leak. However when I read about vacuum leaks etc with the intake side, that's when I decide to take it in. I'm building this on a summer job budget and the last thing I need is a new engine.
Hmmmm... Interesting, I was gonna go for the ls6 and use the $400 for SFC's and possibly a shift kit. I figured those would have a more pronounced effect on driving then the HP increase. I looked and saw people using the ls6 on full heads cam setups so I figured my cam only would be fine. If I can find a really good deal for the fast then I'll think about it.
MASS seller approved
what tranny you running? what gears? usually a stall and gears will give you more for your money. with 224 cam, you will also need hardened pushrods and springs (pac1218s best for quality and durability, 145 on ebay). ls2 timing chain will do. melling oil pump will do. intake, keep yours until you can afford and come up on a good deal on a fast. ls6 intake is good but eventually youre probably gonna end up with a fast so might as well save money now for later.
I'm an A4, I was thinking of doing gears when I get a rear end girdle...
Ok so recently I've been reconsidering my cam choice. After watching videos and people dyno's results it doesn't seem like it won't get my to where I want to be. I know in my first post I said the # doesn't matter however I want to reach that 400rwhp number. So I thought about two options. Having Pat G custom spec my cam, or stepping up to the TSP 228R.
My problem though is TSP recommends a higher stall for the 228R. There is absolutely no room in my budget for the a stall+install. Is there an off the shelf cam that is the largest cam for the stock stall? Or should I just have Pat G custom spec it?
