408 with ai ported 241s
Old 05-16-2013, 06:20 PM
wells01's Avatar
Default 408 with ai ported 241s
Im Im looking to build a 408 on a budget,and was wondering how well the AI ported 241s would work?
Old 05-16-2013, 06:43 PM
garygnu's Avatar
.consider some stock GM ls3 heads from SDPC for $650 a pair.
Old 05-16-2013, 07:34 PM
Blackpanther99's Avatar
Agreed^ LS3 heads will benefit you alot, if not L92s will do a good job also.
Old 05-16-2013, 08:09 PM
Super Hulk Smash
JakeFusion's Avatar
Agreed. The 241s have a pretty small CSA and port for the 408. That being said, they'd probably produce pretty insane torque.
Old 05-16-2013, 08:18 PM
badazz81z28's Avatar
It would probably drive just like my friends mustang...has some snap off the line, but coughs and dies right after. You think he is about to blow your doors off in the 1/4 and than fall on his face. I wouldn't put 241s on anything but a 346.
Old 05-16-2013, 10:15 PM
whatsa347's Avatar
I would think the ls3 with the smaller valves would make a nasty setup, I forget which sponsor sells them but I bet that thing would be a torque monster and make damn good power.
Old 05-16-2013, 10:28 PM
Super Hulk Smash
JakeFusion's Avatar
Yeah - stock LS3s aren't the best for a 4" bore - 2.16" valves are a bit much. The vendor you're thinking of is Ballistic Speed. They have put 2.08" valves in an LS3 head. Their Stage 2 looks awesome: https://ls1tech.com/forums/new-produ...1-engines.html
MAST has also done this. But it costs a whole lot more...
Old 05-17-2013, 04:19 PM
96capricemgr's Avatar
why are you putting the cart before the horse?
Is the 408 a repair?
power is in the topend more than the shortblock, don't let a fixation on displacement cause you to cut corners on the topend.
Now if you wanted to put the AI 243s on a 408 that would be a nice setup.
Old 05-17-2013, 07:14 PM
wells01's Avatar
The 408 is not a repair, just a thought right now. I just seen that some people have used the 241s on the 408 and i was just curious, but I do realize thats not the norm. I have a 01 z28 that I just resently bought, with cam only. A few weeks ago I guess it floated the valves and the intake on
#5 broke the head off, and got pushed back into the seat. The cylinder has some gouges or a crack not sure yet. I was gonna do a 383 if the block was ok, but now im not so sure, may go with the lq9.
Old 05-17-2013, 08:30 PM
100% of airflow has to go through the heads intake and exhaust and is controlled by the cam. What displacement does is allows you to use bigger heads or bigger cam or make the power at a lower rpm, but heads and cam are what really make power.
Point being if budget limited money is better spent on the topend. Ideally you can have both a larger displacement shortblock and a killer set of heads and valvetrain but most of us have limited budget.
If you want to do the 408 as a repair you could consider staying budget on the heads for now with the intent of redoing that later?????????????????
Old 05-17-2013, 09:39 PM
wells01's Avatar
yeah i see now what u meant by repair, so then yeah the 408 would be a repair from the ls1
Old 05-18-2013, 12:24 PM
01ssreda4's Avatar
I'd do it as a hold-over (until I could fund a better top end). It won't be a peak performer but nothing on a budget is.
Quick Reply: 408 with ai ported 241s
