new build piston hitting heads .help
Old 05-17-2013, 11:17 PM
71 chevy's Avatar
Default new build piston hitting heads .help
i sold my lq4 to a guy and just got word that when he bolts the heads down, the piston is contacting the head.
head are unworked 799s
has anyone seen anything like this?
Old 05-17-2013, 11:45 PM
badazz81z28's Avatar
Yeah, its called "piston to valve" contact. Typical when you run a long duration/high lift cam with pistons that don't have valve reliefs. Nothing you can you can do. He needs to fly-cut the pistons or run a smaller cam.
Old 05-18-2013, 12:15 AM
71 chevy's Avatar
sorry, I forgot to mention that he hadnt installed pushrods or rockers. It is not P2V
Im scratching my head on what it could be.
btw, thanks for the post. since I didnt post "500rwhp dyno results" I was afraid I wouldnt get any replies lol
Old 05-18-2013, 12:27 AM
RonSSNova's Avatar
Maybe he forgot head gaskets.......
Pistons usually out .007".......so with no gaskets, they will hit the head,
Is he mocking things up or what is he doing?
Old 05-18-2013, 01:30 AM
mkvamso's Avatar
Thats what id put money on
Old 05-18-2013, 02:13 AM
RonSSNova's Avatar
Or maybe is using 5.7 head gaskets?
Old 05-18-2013, 02:32 AM
mkvamso's Avatar
Its still .056 or so thick
Shouldnt be anywhere close
Old 05-18-2013, 06:25 AM
71 chevy's Avatar
thanks for the replies guys. he did say he is using stock headgaskets.
i forgot to ask if he ordered ls1 or lq4 headgaskets lol cos if he ordered ls1 headgaskets then that would be the problem.
thanks all. i will find out today.
is there any other possible situation that could cause this? i mean, i had 862 and 317 heads on the thing and never had a problem.
Old 05-18-2013, 10:57 AM
RonSSNova's Avatar
If he used 5.7 gaskets and they are smaller than the bore, the piston will hit the gasket. But I've never messed with a 6.0.
Old 05-18-2013, 11:12 AM
JustAFooL's Avatar
I had a friend do this. It would be my guess that the piston is hitting the gasket.. Who knows though.
Old 05-18-2013, 03:30 PM
71 chevy's Avatar
hi, he just double checked the gaskets and they are the wrong ones. he got sent ls1 gaskets instead of lq4.
thanks all for the help
Old 05-19-2013, 08:26 AM
JustAFooL's Avatar
Great to hear, puts you in the clear.
Old 05-19-2013, 10:20 AM
7beast's Avatar
lol iam glad its an easy fix
Quick Reply: new build piston hitting heads .help
