Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)
Old 05-23-2013, 12:29 PM
455GTO's Avatar
Talking Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)
Finally got all the parts together to start the head swap on my 2002 M6 Trans Am. I picked up a set of brand new Advanced Inductions 226cc heads from a member on here(Thank you for an awesome deal!). The heads are spec'd out as follows:
AI 226cc (243 casting)
63cc chambers
PSI 1511 springs with titanium retainers
.040 Cometic head gaskets
Compression= 11.1:1 Static & 8.3:1 Dynamic
The install will be next Sunday followed by a dyno tune on Monday. Based on previous builds I am hoping for a solid 60whp given the bump in compression and new found flow.
Below is the following parts being installed with the heads:
Cometic .040 head gaskets
FAST 36lb injectors
LS2 lifter trays
LS7 lifters
New valve cover gaskets
And of course all new fluids
Current Mods to date that netted 420whp and 390tq
https://ls1tech.com/forums/generatio...ers-added.html
Stock 241 heads
Stock ls6 intake
TSP Tv2 cam 114lsa
Comp 918springs
TSP 1 3/4 LT's
TSP 3" ORY
SLP Power-flo exhaust
SLP Lid
Potz Ported TB
Powerbond 25% UD Balancer
And of course, pics for the build!
Attached Thumbnails Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)-revisedheadpackage.jpg   Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)-fullheads.jpg   Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)-heads.jpg
Old 05-23-2013, 12:57 PM
badazz99ss's Avatar
Nice setup in for the build
Old 05-23-2013, 01:22 PM
455GTO's Avatar
Pics finally loaded correctly
Old 05-23-2013, 05:06 PM
mac62989's Avatar
Are you going to the same dyno you hit 420 rwhp with?
Old 05-23-2013, 05:20 PM
455GTO's Avatar
Yes, same dyno where I did my bolt-on pulls and cam pulls.
Bolt-ons I made 357whp and 367wtq. Should be interesting to compare all 3 pulls to see how the car has progressed.
Old 05-24-2013, 10:09 AM
Rise of the Phoenix's Avatar
Sounds like a great build. One question for you; are the heads stamped 63cc anywhere? I know you said they are milled down to 63cc, so wasn't sure if AI stamped them. I've got the AI Dart/RHS CNC'd heads, milled down to 60.5cc, but they were not stamped. I verified with AI that they were milled to my desired specs and they told me they were. Just curious if yours got marked.
Old 05-24-2013, 10:42 AM
onefast84's Avatar
Looks nice! Interested in how it runs! Are you planning any track outings? It is similar to my build, and was interested in what kind of E.T.s it put down. Its going to be a while til I get to the track myself.
Old 05-24-2013, 10:48 AM
pauls99z28's Avatar
in for results too..
Old 05-24-2013, 12:26 PM
455GTO's Avatar
No, they were not stamped with anything from AI. OEM 243 markings were left in tact and no "cc markings". But that would be nice if they could start doing that!
Yes of course! I will be going to Famoso raceway on June 14th for the Friday night test n tunes. The air is always horrible out there compared to where I live, which is sea level. The east coast guys have it so lucky out there with nice air year round. I am hoping for 118+ traps and around 11.80ET... I'm on the stock 10 bolt so getting a good launch isnt a real option.
Thanks! Will be updating with build pictures when the heads are being put on.
Old 05-24-2013, 02:04 PM
mac62989's Avatar
Ive seen AI write with marker the cc on the heads if thats what you mean by stamping..
Old 05-24-2013, 03:30 PM
I've seen heads that have been milled "stamped", which is just a very small number that's been indented into the heads. Say you had them milled from 67cc down to 63cc, there would be a "63cc" stamped onto the deck of the heads; very small and around one of the corners. I was just curious because my heads were not stamped and there was nothing marked on the indicating the cc size.
Old 05-24-2013, 03:33 PM
mac62989's Avatar
Ah I see. Like I said Ive seen it written around one of the corners, once in person and twice on the interwebs. Maybe they just write it on the invoice these days.
Old 05-24-2013, 03:38 PM
Wasn't on the invoice either, which is why I called to find out. I called their voice message number and left my number and received a text back verifying they were milled to my specs.
Old 06-01-2013, 05:09 PM
455GTO's Avatar
Install is set for tmrw! I will be updating along the way with pics and should all be finished tomorrow. Tune on Monday!
Old 06-03-2013, 04:14 PM
455GTO's Avatar
Heads are on and car runs great! The motor ended up needing 7.350 push rods which was a surprise. Dyno tune will be done at 6pm today and I will posting up the graph and some pictures.
Old 06-03-2013, 08:18 PM
97camaro383's Avatar
Results????
Old 06-03-2013, 08:53 PM
showvette's Avatar
In for results too...
Frank
Old 06-04-2013, 12:14 AM
455GTO's Avatar
Results are in!!!
Ended up making 443.9rwhp and 408.8rwtq. Not the big numbers I was expecting, but happy nonetheless. I just do find it odd that I only picked up 23hp from the heads... We played with both AFR and timing to see what it liked best, and we settled with 29* from 5500rpm on up along with 12.8AFR.
What impressed me the most was how much smoother the graph is now. Seems like the added quench and flow really helped that out. Attached is the graph that compares my bolt-on, cam only, and now heads/cam pulls. AFR graphs also attached. Again, this is with the stock ls6 intake so I imagine I could get close to 460rwhp with a FAST92 set up.
Anyone think the "smallish" cam is holding me back?
Thanks for following!
Attached Thumbnails Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)-allgraphs.jpg   Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)-allafr.jpg
Old 06-04-2013, 09:40 AM
455GTO's Avatar
Up for today
Old 06-04-2013, 09:50 AM
Congrats! I think the numbers look pretty good!
Quick Reply: Advanced Inductions 226cc w/ TV2 Cam Build(Dyno Added)
