Am I over-sprung?
Am I over-sprung?
I've done some research but I can't find any clear guidance. I'm looking for advice on what others have done.
I'm running new AFR 210 V2 heads on with the standard springs. They are a double-spring style. Here are the spring details:
Part No. AFR-8017
360 lb/in
0.600" max valve lift
135 lb on seat
Here is my cam card:
Here are the rest of my valvetrain components:
GM lifters (aka LS7), 0.045" preload
Comp Chrome-moly Pushrods
Comp rocker trunnion upgrade
AFR titanium retainers
2.02" stainless intake valves, AFR-7207
1.60" stainless exhaust valves, AFR-7228
I've read where others have used a single beehive style spring with a similar sized cam as me. What do you guys think? Would I benefit from a different spring?
I don't spin the motor past 6k, and I'm mostly interested in driveability and longevity of components.
Any guidance is appreciated, thanks!
Part No. AFR-8017
360 lb/in
135 lb on seat
giving lift numbers are good and all, BUT....... what if the ramp rates are extremely aggressive. I wish when people toss around their cam specs, they would include lobes.
Those appear to be xe lobes which arent aggressive. What more do you need besides that cam card? Theres a 53 degree split between the .050 and .006 duration giving you a ramp rate of 53. Thats soft for average lsx camshafts.
