DBW to DBC conversion
Old 06-13-2013, 02:10 PM
gmcyukon's Avatar
Default DBW to DBC conversion
Has anyone ever did a conversion if so could you help me out. I'm thinking about doing this
Old 06-13-2013, 03:38 PM
2000PewterT/A's Avatar
Try posting in the conversion/hybrid page or searching, this has been covered before. I am not sure on the details on what is involved so I can't answer this with 100% assurance.
Old 06-13-2013, 03:52 PM
Bobby G's Avatar
I did it on my LQ4. You have to get a DBC computer, and change some of the wiring
Old 06-14-2013, 01:25 AM
gmcyukon's Avatar
Damn just got my PCM tuned oh well thanks bud
Old 06-14-2013, 11:14 AM
Bobby G's Avatar
call PSI....I switched my DBW to a DBC with them.....they are good guys....bought my wire harness from them too
Old 06-15-2013, 06:39 AM
RezinTexas's Avatar
if you're using a stock intake manifold, you will likely have to install 2 brass threaded inserts to run the cable mounting bracket. see pic below, the red circles indicate the inserts that had to be added.
http://www.mcfeelys.com/product/3606...hreaded-Insert
Old 06-15-2013, 07:26 AM
96capricemgr's Avatar
Couldn't you just have the tuner set it up to have the throttle do exactly as you do with the pedal?
I thought all the delay and such was programmed torque management not actually slow electronics.
If putting a DBW engine in an older vehicle I can see going cable to avoid mounting a new pedal but that is not what it sounds like you are doing.
Quick Reply: DBW to DBC conversion
