ls2 rod with mahle piston
Old 06-16-2013, 09:04 PM
Go5.3tt06's Avatar
Default ls2 rod with mahle piston
I have a questions for you. If Im going to do LS6 3.898 block since I have ls2 rod with .945 floating I think. And want run mahle flat top piston. Is it bad idea to use stock ls2 rods? What compressor ratio would be for that and run 243 heads. Let me know what do your opinion. Many thanks.
Old 06-16-2013, 09:07 PM
garygnu's Avatar
the ls2 rod will allow for better rod bolts.but consider a 383 rotating stroker assembly .
Old 06-16-2013, 10:01 PM
Go5.3tt06's Avatar
id like stay 5.7 346 it is just for my s10 truck project.
Quick Reply: ls2 rod with mahle piston
