LS2 block can be bored to...?
Old 06-16-2013, 09:06 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Default LS2 block can be bored to...?
The LS2 has a 4.00 bore. Can it safely be taken to 4.030? No boost/juice.
Old 06-16-2013, 09:29 PM
Darkman's Avatar
According to J. Potak's book the listed max bore is 4.020" with a footnote that states that the 4.02 is a Factory Specification but 4.030" is obtainable.
Old 06-16-2013, 10:10 PM
Paul Bell's Avatar
Thanks!
I have that book.....
Old 06-16-2013, 10:15 PM
Paul Bell's Avatar
This works out nicely. 4.030 with a 4.125 stroke makes 421 inch-a 71 inch bump my my tired high mileage LS1.
Now for some nice heads....
Old 06-16-2013, 10:49 PM
PREDATOR-Z's Avatar
I would keep the motor square to reduce potential oil consumption issues.
Old 06-16-2013, 10:58 PM
Paul Bell's Avatar
yes, that's something to consider.
Old 06-16-2013, 11:57 PM
Super Hulk Smash
JakeFusion's Avatar
A 403 (4.005x4) or 404 (4.010x4) would give you a nice boost with a good set of heads. 530rwhp is attainable with the right setup with a 402. 550+ is possibly as well if you're willing to go all out. That's a nice bump over where you are now.
Old 06-17-2013, 08:15 AM
LS1-450's Avatar
Excuse my ignorance. By square do you mean match bore to stroke? How is oil consumption increased? Thanks
Old 06-17-2013, 10:06 AM
PREDATOR-Z's Avatar
Yes, see when increasing stroke you bring the piston further down in the cylinder which exposes the bottom of the piston out of sleeve further at BDC. This action allows the piston to rock more and eventually can lead to an increase in oil blow by consumption.
One could resleeve with longer sleeves and that helps if one is set on running bigger than 4.00 stoke.
Old 06-17-2013, 10:10 AM
Coonass350's Avatar
Learn something new everyday
Old 06-17-2013, 10:12 AM
Paul Bell's Avatar
Originally Posted by predator-z
yes, see when increasing stroke you bring the piston further down in the cylinder which exposes the bottom of the piston out of sleeve further at bdc. This action allows the piston to rock more and eventually can lead to an increase in oil blow by consumption.
like^
Old 06-17-2013, 11:11 AM
Paul Bell's Avatar
My goal is to reach 427 inches-or so. The LS7 block is rather costly. With a four inch stroke, it'll have longer sleeves? Are the sleeves in a LS3 block as long as in the LS7 block?
Old 06-17-2013, 11:57 AM
KCS
Moderator
KCS's Avatar
Nope.
Old 06-17-2013, 01:40 PM
The_Bishop's Avatar
I wouldn't get hung up on the couple of cubes a max bore will buy you. Bore it what it *needs* to clean up, you'll have a more stable bore under power and make more power as well as being more durable.
Old 06-17-2013, 02:50 PM
Super Hulk Smash
JakeFusion's Avatar
LS3 block + 4.100" stroke would be an okay combination. 4.07" x 4.1" would get you 427 on the nose. Wiseco makes pistons for the 4.100" stroke that reduce some of the oil consumption issues. However, you end up with a thin crown on the piston, so it's pretty much an NA only setup or very mild boost/nitrous. It's only a little bit more expensive than the LS2 and a cheaper alternative to the LS7.
Old 06-17-2013, 04:24 PM
64post's Avatar
An easy way to decide your combo: Divide your rod length by the stroke, if the number is lower than 1.50, try and avoid it. A 6.125"rod length divided by 4.0 =1.53, still reasonable. A 6.125 length divded by 4.250' =1.44, not so much.
Old 06-17-2013, 05:05 PM
Blackpanther99's Avatar
Lots of good new info for me
Old 06-17-2013, 05:41 PM
Paul Bell's Avatar
Originally Posted by KCS
Nope.
Hey KCS thanks for that. Could you elaborate? What is the difference in length?
Old 06-17-2013, 05:43 PM
Paul Bell's Avatar
YEP. That's why I'm not looking at a 441.
Old 06-17-2013, 06:02 PM
Paul Bell's Avatar
Originally Posted by 64post
An easy way to decide your combo: Divide your rod length by the stroke, if the number is lower than 1.50, try and avoid it. A 6.125"rod length divided by 4.0 =1.53, still reasonable. A 6.125 length divided by 4.250' =1.44, not so much.
I'm looking at rods at 6.125 and a stroke at 4.125. The resultant ratio is 1.48.
The rotating assembly I'm looking at is the new kits from Wiseco with K1 cranks & rods-unless somebody think's it's not a good product/kit.
Quick Reply: LS2 block can be bored to...?
