Question about valve spring swap on 6.0
Old 06-22-2013, 08:17 PM
Torvus's Avatar
Default Question about valve spring swap on 6.0
I have a set of dual valve springs and when going to install them on a stock 317 head I notice the inner spring sits high as there's a shoulder at the bottom of the spring land. I'm assuming that this is incorrect? Wrong inner sprin diamter? They fit stock ls1 heads with an inner diamter of .675 or something. Thanks.
Old 06-22-2013, 08:36 PM
Torvus's Avatar
Or is this completely normal?
Old 06-22-2013, 09:06 PM
kennypowers's Avatar
did you change to the correct valve seals?
Old 06-22-2013, 09:14 PM
Torvus's Avatar
Valve seals are right. The issue (or perceived issue) is these heads have a shoulder at the bottom on the valve guide which the inner springs perch on and don't go all the way down to the spring seat like the outer springs do.
Old 06-24-2013, 05:54 AM
Brian Tooley Racing's Avatar
Can you post a picture of this shoulder?
Just to verify, you have small seals required for dual springs like these? http://www.briantooleyracing.com/ls-valve-seal-kit.html
And not stock "hat style" seals like these? http://www.briantooleyracing.com/ls-...hat-style.html
Quick Reply: Question about valve spring swap on 6.0
